TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Help with DS1 6000k Xenon install problems!
      07-19-2010, 01:55 PM   #1
Domonation
Bimmer Nub
Domonation's Avatar
7
Drives: '08 335i
Hey guys,
I got DS1 6000k Xenons to replace my OEM 4300k for my birthday this weekend. My friend and I installed it this weekend. It worked great the for the night and looked so much better.
However, the next day I was driving and my low beam check light came on. I noticed that my xenons were no longer on. They seems to autofocus when I turn on the car but no light comes out. The connections seem fine as far as the power to the headlight and the connector to the low beam.
I tried replacing with the old bulb and now the old bulb doesn't work either!!
I'm thinking about just taking my car back to the dealership and try to have them fix under warranty.
Thoughts?
| '08 335i | Blk Saph | PREM | CWP | SPT | Matte Blk Grilles | 20% Tint | Shadow Emblem | Blk Roundel | MTEC AE | HID Fogs |
Future Mods Wishlist: JB3 | 19" VMR v710s |
      07-19-2010, 02:52 PM   #2
Mike@F1 Autohaüs
Mike@F1 Autohaüs's Avatar
195
Drives: ❤
I'd put the stock bulbs back in and bring it to the dealer
      07-19-2010, 04:08 PM   #3
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
replace with OEM bulbs and bring it back to the dealer
      07-20-2010, 03:47 PM   #4
Domonation
Bimmer Nub
Domonation's Avatar
7
Drives: '08 335i
That's what I plan on doing. However, when I was removing the back casing to the front left headlight, I dropped it cause the car was too hot. Had to do my work outside in the baking sun is no fun.
Now the casing is stuck in below inside the bumper. I think the only way I can get it out is to remove the fender by the wheel well.
Thoughts on how I can get it out before I hit the dealership?
I've also heard that I could just be a blown fuse too from some searching.
      08-20-2010, 07:41 PM   #5
BoStoNe90
BoStoNe90's Avatar
60
Drives: E90/F30
D1S bulb
Just wondering if you ever had that problem fixed? I changed out my stock xenon bulb 2 weeks ago with the 6000k bulbs from ddmtuning. Then a week later my passenger side bulb went out. Checked all wiring and try to replace them with the stock. And same here no luck. Only problem I have is that my warranty on my car already expired and i don't know what the problem is. Last resort is bring it to the stealership because I have no warranty left. So any help you can give me would be much appreciated. Thanks
      08-23-2010, 09:12 PM   #6
curamie
34
Drives: 08 e90 335i SG
here I found same thing on my 08 e90 335i
I've used aftermarket d1s bulb for an year and one of my passenger side wouldn't work..
I put stock back in and still wont work... now i have to put my stock angel eye for warranty work also...
OP, if u find anything, pls let us know will do the same
      08-24-2010, 10:11 AM   #7
MyE92
El Presidente
MyE92's Avatar
Drives: your mom wild.
Wait, I'm about to switch to 6000k D1S bulbs... Should I not?
      08-24-2010, 06:45 PM   #8
psquires
Drives: 08' 335I E90
Me too!! but getting back to the topic.. Domonation What brand D1S bulbs did you use? did you get them on ebay???
      08-24-2010, 06:52 PM   #9
robb41488
Drives: 335i
from what ive read around here before. leave the oem lamp in the car for a day or so. after a few starts and turn ons of the switch the lamp should be "recognized" and work again
      08-24-2010, 09:37 PM   #10
Alex@Alpine
1303
Drives: E90 M3
^He is correct.
I once purchased some eBay D1S bulbs thinking I was saving money, they did the same thing, I disconnected the battery for 15minutes, then I turned the car back on drove it around for about 2 miles and it came back on.
China has been cutting down a lot lately on material, you wont even see copper in wires anymore, it just sucks! All this is causing errors in many after market car electronics.
      08-24-2010, 09:38 PM   #11
Alex@Alpine
1303
Drives: E90 M3
Oh, I forgot to add, the reason that happened was because when I was putting the bulbs in, I bent some of the pins which I think caused a short circuit. Put the stocks back in, then I did the battery thing and drive.
      08-24-2010, 09:57 PM   #12
MyE92
El Presidente
MyE92's Avatar
Originally Posted by Alex@Alpine View Post
^He is correct.
I'll be honest, I purchased my D1S bulbs off of ebay. Should I not install them? Or will they be OK after I disconnect the battery for 15 mins and turn the car back on?
      08-25-2010, 12:19 AM   #13
mcrazyrider
mcrazyrider's Avatar
Drives: 2022 X3
08 E90  [0.00]
I got the same exact problem a few weeks ago, the new 6000K lights blew the HID control module and the ignitor and I have to bring the car 2 consecutive times to the dealer until they replace all the faulty parts and now the lights are working fine. Install stock lights back and take the car to the dealer.
      08-25-2010, 08:19 PM   #14
MyE92
El Presidente
MyE92's Avatar
Would a resistor solve the problem?
      08-25-2010, 08:27 PM   #15
Alex@Alpine
1303
Drives: E90 M3
There is no where or reason to put a resistor, it's just bad ignitors in the D1S unit.
      08-25-2010, 11:06 PM   #16
Silvercoupe
Silvercoupe's Avatar
115
Drives: 335i coupe
Anyway op I think u have bad ballast , replace your stock bulb back in and go to dealer demand for new ballast or whatever else that might cause you the headache if your under warranty ...
<img src=http://i658.photobucket.com/albums/uu305/LEDConcept/08aebdd0.jpg border=0 alt= />
      08-27-2010, 10:03 AM   #17
MyE92
El Presidente
MyE92's Avatar
^He is correct.
Does this really work? I purchased eBay bulbs and I'm about to install them... I still don't know if I should.
      08-27-2010, 10:08 AM   #18
Alex@Alpine
1303
Drives: E90 M3
Follow the sellers feedback, and that should give you an idea. People voice their concerns quick on eBay feedback pages, if the seller is a big seller, go to the bottom click on "200" to show 200 feedbacks per page, then just cruise through a few pages till you see the Red Negative logo, and read their comments.
      08-27-2010, 10:13 AM   #19
MyE92
El Presidente
MyE92's Avatar
Well what I really mean is... Is it safe to change out the HIDs. It looks like everyones running into problems after changing theirs out.
      08-27-2010, 10:40 AM   #20
Alex@Alpine
1303
Drives: E90 M3
It is qaulity of the product which would be the answer. I do not want to kick a good product down because a seller is selling it on eBay. It is trial and error, that is why we have threads like this to point out problems. If you are really worried, I would be extra careful with the install and also to make sure, purchase from one of the great vendors on the forum who are trusted.
      08-27-2010, 10:45 AM   #21
cb1111
I ask the questions you're afraid to ask.
cb1111's Avatar
44
Drives: 335xi
Absolutely correct. Since these products fail to meet any required specs, there is no guarantee of any quality control either.
Given the very low failure rate of OE headlights, it cannot be coincidence that these aftermarket bulbs are causing ancillary failures.
      08-27-2010, 10:57 AM   #22
Alex@Alpine
1303
Drives: E90 M3
Couldn't have said it better myself.
I sell D1S bulbs, but I always tell everyone who is purchasing them, there is nothing like stock, the reason all these higher temp colors started out was because people were attempting to get the color Factory Xenon Projectors where putting out at a distance out of their stock halogen housings.
If you look at your BMW coming at you from a distance, the projectors will give off that blue/purplish look, I understand standing next to the car looks yellow, but honestly, who stands next to your car looking at the projectors that close?
License plate lights, interior lights, Angel Eyes, and so on I understand, thats all cosmetic, low beams are used for night driving and you need the most light you can get, going higher in temp on your low beam causes loss of light, do not let the blue color on the floor fool you into thinking you are getting more light...
