Torque specs - differential
07-18-2010, 03:29 PM | #1 |
273
Rep 5,876
Does anyone have the torque specs for the following (or know where I could find these):
1) Insert nut that connects the rear of the driveshaft to the differential 2) Half-shaft torx bolts Need to supply these to a tranny shop next week. They're looking into a noise/clunk issue with the recently installed wavetrac LSD. It happens only on hard/fast upshifts, as the shifter goes into gear (sound is definitely from the rear). From reading up on some posts it might be that the insert nut isn't tightened enough. Doubt its a backlash issue as noise wouldn't be isolated ONLY to hard/fast upshifts...it'd be heard on acceleration as well... |
07-18-2010, 07:58 PM | #2 |
ahat
1036
Rep 2,592
I have the CD at the other house - I will update this thread on monday afternoon.
edit Check here - http://s626.photobucket.com/albums/t...orqueloads.jpg
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 Last edited by 335e92tx; 07-18-2010 at 08:42 PM.. |
07-18-2010, 08:43 PM | #3 |
133
Rep 4,764
You need the Bentley Manual.
Rear driveshaft to differential (flange nut) 75nm (55ft-lb) Driveshaft axle to diff flange: Torx M8 = 38.3 ft-lb (this is what I think you are asking about, these are the only bolts I replaced for my complete final drive quaife unit install from Harold) Torx M10 = 51.6 ft-lb Torx M12 88.5 ft-lb You should really get a hold of the Bentley Manual. Lots of other torque specs, things that should not be re-used, etc. Confirm these numbers above with more a few more people. Good luck. Last edited by scottp999; 07-18-2010 at 08:48 PM.. |
07-18-2010, 08:50 PM | #4 | |
119
Rep 2,703
07-19-2010, 10:51 AM | #6 | |
23
Rep 1,179
the thud you hear is usually caused by bad EGS parameters -- the EGS (transmission) control unit needs to be reprogrammed to eliminate that issue. |
