Clear or keep for service?
07-17-2010, 01:40 AM | #1 |
924
Rep 15,818
Taking my car in Monday for brakes/squeaking from the front
got a SES light today Following codes: 2C31: 2C31 Lambda probe in front of catalytic converter, trimming control Error will cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold Freeze Frame Information Event 2 Odometer 27872kms 17318miles voltage Lambda probe behind catalytic converter bank 1 0.66 V voltage Lambda probe in front of catalytic converter bank 1 1.91 V Lambda shifting return valve 1 0.00 - input signal return valve 1 0.00 V Event 3 Odometer 27984kms 17388miles voltage Lambda probe behind catalytic converter bank 1 0.74 V voltage Lambda probe in front of catalytic converter bank 1 1.52 V Lambda shifting return valve 1 0.00 - input signal return valve 1 0.00 V 29CD: 29CD Misfirings, cylinder 1 Error will cause a warning light Error is not currently present Test conditions have been completed Timeout Freeze Frame Information Event 2 Odometer 27848kms 17303miles Engine temperature 99.75 °C load value for misfire detection 38.28 % Engine speed 3,232.00 rpm Lambda integrator group 1 0.00 % Event 3 Odometer 27848kms 17303miles Engine temperature 107.25 °C load value for misfire detection 25.78 % Engine speed 736.00 rpm Lambda integrator group 1 0.00 % 2C32: 2C32 Lambda probe in front of catalytic converter 2, trimming control Error will cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold Freeze Frame Information Event 2 Odometer 27912kms 17343miles voltage Lambda probe behind catalytic converter bank 2 0.70 V voltage Lambda probe in front of catalytic converter bank 2 1.70 V Lambda shifting return valve 2 0.00 - input signal return valve 2 0.00 V Event 3 Odometer 28000kms 17398miles voltage Lambda probe behind catalytic converter bank 2 0.70 V voltage Lambda probe in front of catalytic converter bank 2 1.74 V Lambda shifting return valve 2 0.00 - input signal return valve 2 0.00 V Safe to keep or should I clear them ? I know they're 02 sensor codes plus the misfire Went through Mr. 5s BT code list... not listed.. Just want to see if it's safe to keep.. i need my warranty
07-17-2010, 09:08 AM | #2 |
I ask the questions you're afraid to ask.
44
Rep 2,489
If you need your warranty then don't mod your car. This seems a prime example of why BMW should refuse warranty service on modded cars.
If a mod caused an issue then man up to it. You've got to pay to play. Trying to cover up problems caused by a mod doesn't help in the diagnosis and, once detected, makes the dealership unhappy with any modded car. |
07-17-2010, 09:43 AM | #3 |
103
Rep 2,783
Since they are working on your brakes, I would clear it in case they check for codes. You wouldn't want them to find something in there that alerts them your car is/was modded. Now go and mod no more.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
07-17-2010, 10:47 AM | #4 |
924
Rep 15,818
Well since this forum unfortunately doesn't give as much advise as it does criticism, I went to a better source: BMW and Terry
2C3X codes are O2 codes that are NOT related to tuning. Rather, a bad/damaged O2 sensor But still safer to clear it due to my catless DPs /Thread
