need help. bms dci
07-16-2010, 11:37 AM | #1 |
Rep 195
need help. bms dci
After hearing all the good reviews of BMS DCI, I finally purchased one and installed it.. and i have a few questions...
1)DCI sounds barely noticeable(almost like stock) in low rpm range, and it only sounds like sucking up air and the turbo spool when I go in high rpm range(when i floor it)? does this sound right? 2)after installation of DCI, I felt like more heats from engine bay were getting transferred into the car for example, heat coming from behind the steering wheel, and from where the brake pedals are. thus making the temperature of inside the car go up... your help will be appreciated. thanks |
07-16-2010, 11:48 AM | #2 | |
424
Rep 1,325
07-16-2010, 12:16 PM | #4 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
07-16-2010, 12:16 PM | #5 |
12
Rep 150
intake install
Did you get your cowl back on tight? It has that cabin filter too maybe not secured so hot air coming through cabin filter?
Def. can hear the turbo spool and air sucking - I enjoy to hear a little something w/ the mod instead of silence of stock so no worries on that part. Good luck!
E92 M3
07-16-2010, 03:14 PM | #10 |
127
Rep 4,732
07-16-2010, 04:03 PM | #11 | |
475
Rep 13,583
Drives: JB E92 335i
The aFe Dual Filter Cold Air Intake System replaces your restrictive factory air box which allows for an increased air flow meaning more horsepower. Another feature of the intake is the 16 gauge powder coated steel heat shield. A heat shield makes sure that the intake doesn't use the hot air around your engine and only allows the intake to receive cooler air, which adds more power. Not only does power increase, but many have observed an increase in MPG. The answer is subjective but we've had nothing but positive feedback about the aFe system! aFe has two different systems out for the N54: 1) aFe Dual Filter Cold Air Intake System 2) aFe Elite Stage 2 Si Intake System (more expensive system) Feel free to give me a shout if you guys have any questions at all! - Alan |
07-16-2010, 06:03 PM | #12 | |
4918
Rep 115,980
Mike |
