Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Vishnu Update 7/13/10
      07-13-2010, 09:11 PM   #1
OpenFlash
Drives: A Lot
Exclamation Vishnu Update 7/13/10
Just a little heads up. We will be releasing new firmware and user software tomorrow.
User Software changes
-Revised user adjustable names
-Netbook compatability
-Various misc improvements
Firmware-Built-in Dual Wideband AFR monitoring/logging functionality. Now displays ACTUAL AFR instead of DME-perceived AFR.
-Built-in safety feature that monitors both AFR channels (bank 1 and bank 2) for leanrun conditions. Valet is tripped if leanrun occurs.
More later....
      07-13-2010, 09:15 PM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
      07-13-2010, 09:29 PM   #3
TurboSid
TurboSid's Avatar
1111
Drives: 2022 M4Cx BSM/FR
2008 335i  [0.00]
Shiv was it you who had a plx made display gauge that worked with the procede? what are our options if we wanted to monitor AFR and any other parameters w/o a laptop
2022 BSM/FR M4 Competition X-Drive
2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD]
      07-13-2010, 09:35 PM   #4
TMR
TMR's Avatar
Drives: M3
AWESOME!!!
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/
SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/
SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/
      07-13-2010, 09:51 PM   #5
335iLI
34
Drives: 335i
Shiv whats going on with the in dash boost display.
      07-13-2010, 10:05 PM   #6
Malaka1
Malaka1's Avatar
Drives: F30 335i 6MT Black
-Netbook compatability!!!!!!!
      07-13-2010, 10:29 PM   #7
gian335
gian335's Avatar
36
Drives: e92 335
nicee....hope they come with new upgraded turbo maps aswell
      07-13-2010, 10:32 PM   #8
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
Originally Posted by Malaka1 View Post
-Netbook compatibility!!!!!!!
Sorry, I had to...
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      07-13-2010, 10:36 PM   #9
dzenno
273
Drives:
AFR monitoring is F* AWESOME!! thank you for having mercy on us netbook users...
Any chance you could do something about datalog naming/organization so we don't overwrite previous logs on restarts of procede software??? This'd be sooo helpful..
      07-13-2010, 10:54 PM   #10
cn555ic
cn555ic's Avatar
Drives: 335i
When you save the file just rename it to a different number!
Shiv..BTW do you have an ETA of when you will introduce the nitrous documentation...You stated awhile back that when you came back from vacation that it would be up...Thanks
      07-13-2010, 11:00 PM   #11
dzenno
273
Drives:
I'd rather not bother with this EVERY single time..how hard is it to not restart the counter or just use a millisecond timestamp instead of counter..believe me this is annoying..
      07-13-2010, 11:06 PM   #12
R1000K3
R1000K3's Avatar
Drives: 335i MT
Originally Posted by shiv@vishnu View Post
J.....Valet is tripped if leanrun occurs.
Great, this will also be an important safety feature for N20 usage.
      07-13-2010, 11:20 PM   #13
scottp999
133
Drives: 4runner SR5
2007 BMW 335  [9.00]
Great news! Thanks.
      07-13-2010, 11:49 PM   #14
forza1976
forza1976's Avatar
Drives: BMW
2022 BMW M3X  [10.00]
cool man
      07-14-2010, 02:19 AM   #15
Malaka1
Malaka1's Avatar
Originally Posted by vasillalov View Post
Sorry, I had to...
Had to what?
      07-14-2010, 02:42 AM   #16
OpenFlash
Drives: A Lot
See if you notice any changes:
      07-14-2010, 02:45 AM   #17
TMR
TMR's Avatar
Drives: M3
I LOVE IT!!!!!
      07-14-2010, 03:22 AM   #18
AltecBX
AltecBX's Avatar
Drives: BMW 335xi Sedan; BMW M3 ZCP
2018 BMW M3 ZCP  [0.00]
2007 BMW 335Xi  [0.00]
Talking
- maps name are in a text box
- overboost by .01 sec
- initial boost instead of user boost
- ign correct to 0-100 %
- speed delimiter is on by default
- wastegate position at 100% instead of 90%
- F key logging
- adjustable window sizing
Why is upshift softening at 100 when max value is 50?
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps)
†Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec
AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS
      07-14-2010, 03:25 AM   #19
OpenFlash
Drives: A Lot
- F key logging
oh... ignore the actual values in the user adjustable menu. There was no map loaded hence the non-plausible values. I was just showing the changes to the text in the windows.
      07-14-2010, 03:36 AM   #20
AltecBX
AltecBX's Avatar
Cool.
Shiv, can you add F keys for "channel setup" and "view data log" as well?
      07-14-2010, 03:41 AM   #21
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
      07-14-2010, 04:10 AM   #22
ericsmc83
ericsmc83's Avatar
Drives: 08 E92 335i MT
Netbook/F-Key support FTW!
Looking forward to the new AFR channels. Great job!
2008 E92 MT | VTT Stage 2+ 20T | VTT Inlets | JB4 MHD E85 | Fuel-It Stage 3 LPFP w/FPR and Return | BMS PI | AR DP | AE Quad Exhaust | Helix FMIC | ER CP | Tial BOV | DCI | AR OCC | Spec Stage 3+ | SMFW
