Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Light upgrade help ASAP
      07-12-2010, 06:10 PM   #1
mcrazyrider
mcrazyrider's Avatar
Drives: 2022 X3
08 E90  [0.00]
here i my situation, saturday night upgraded to 6000k HID lights test it after instal and it was working great, drove the car arround sunday and lights still working. Monday morning driver side light was not on only the passenger side, before i got to work the pasenger side went off. this evening coming back from work passenger side came back on but driver side still off. I swap to the driver side to the OEm light ans is stil off not working at all only the angel eyes work also the hi beams com on. Any ideas? is there some king of fuse for the hid light only? If I can get it to work i will swap the OEm light back on and take it to the dealer. please help.
      07-12-2010, 07:37 PM   #2
buckshizzo
buckshizzo's Avatar
Drives: '09 JB E92 335i
A couple questions. Does your car come with HIDs stock or are they an aftermarket set of HIDs? How did you connect it? It Sounds like you might have a loose connection. Check the connection to the back of the bulb and make sure it's secure.
      07-12-2010, 08:35 PM   #3
mcrazyrider
Drives: 2022 X3
08 E90  [0.00]
the car comes wih the oem hid and i tested the new bulbs on the driver side and they work fine, i plugged the original bulb on the driver side and is still not turning on.
      07-12-2010, 09:18 PM   #4
SV Concepts III
375
Drives: BMW Duh
You could have a bad ballast/igniter on that one side if both sets of bulbs do not work.
      07-12-2010, 09:57 PM   #5
Mike@F1 Autohaüs
Mike@F1 Autohaüs's Avatar
195
Drives: ❤
I'd take it to the dealer since it's still under warranty
      07-12-2010, 09:58 PM   #6
mcrazyrider
Drives: 2022 X3
08 E90  [0.00]
thanks for the help I'm installing all the OEm light bulbs back and taking the car to the dealer to have it check and changed under warranty.
