Switched 12v power source for meth kits in trunk?
07-11-2010, 02:08 PM | #1 |
49
Rep 966
Had to dive into the Bentley manual today and I noticed they say there's a "rear 12v utility socket" behind the trim on the left side of the trunk. I took out a couple of the clips and pulled the trim away but couldn't see it.
I was too lazy to remove the rest of the trunk trim, so thought I'd ask if anyone has seen/ used this socket. Would be a great location if it's 12v and switched to power meth kits. For those with the Bentley manual it's on pg ECL-43, Fig 44. |
07-13-2010, 09:03 AM | #5 |
133
Rep 4,764
Another question: What circuit and fuse does it run off of? I still like the idea of using an unused circuit. If this one is on it's own circuit then great. If it uses the same cig lighter circuit then I would avoid it.
07-13-2010, 09:29 AM | #6 | |
263
Rep 2,559
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
07-13-2010, 09:42 AM | #7 |
56
Rep 1,311
You can create a new fused circuit by controlling a relay from the switched trunk source and connect the meth stuff via the realy directly to the battery. The new fuse shall be located as close to the battery as possible.
07-15-2010, 05:03 AM | #9 |
58
Rep 1,230
Running meth controllers and fail safes directly from the car battery 12v source is the ideal power setup and doing it via a switched 12v source that controls a relay is the way to go.
