Problem with V4 car solved
07-08-2010, 10:18 PM | #1 |
56
Rep 1,311
A fellow’s E92 AT has begun to limp frequently after upgrade to V4 Autotune. When I tested the car yesterday it runned very strong during a couple of seconds at each WOT but then always limped. A check showed that the boost pressure was too high, sometimes up to about 20 PSI and the actual boost did not respond to settings in the Procede User Software. Problem solved by reloading the firmware and maps, so something did get wrong at the previous upgrade. The battery in the car is not in a very good condition and it has also been connectivity problems with the guys PC, which explains the Procede was corrupted.
The car is provided with DCI, Big Tom intake heat shield, aftermarket FMIC and use stock DP’s. I’m quite impressed how strong it now pulls. Meth is not used and the max boost is set to 14 PSI on map 1 and 16 PSI on map 2. The setting of map 2 is a bit high for stock DP’s, but the car runs flawlessly on 94 octane RM2 with this setting and the DP’s will be replaced with catless 2,5”. |
07-09-2010, 12:34 AM | #2 |
184
Rep 2,841
Whenever my car starts acting weird regarding boost.....I reload the firmware making sure the laptop is connected to an electrical outlet.
Always seems to solve the problem with boost fluctuations. Sometimes I notice my usb port will drop signals momentarily when I am datalogging, so I am sure it can happen during a firmware download. And I do have the laptop power settings at high perfomance. |
07-09-2010, 01:43 AM | #3 |
219
Rep 3,012
The simplest things. And yet its heavily mentioned that this is an issue. You'd think that if there was corruption that it wouldn't function at all... Maybe the procede should add a CRC check to the firmware... Seriously.
07-09-2010, 01:45 AM | #4 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Yep... We will have a checksum function coming soon. In the meantime, just update firmware with the laptop plugged into an ac socket.
07-09-2010, 02:07 AM | #5 | |
56
Rep 1,311
One of the boost logs from this guys car shows 22 PSI, which is extremely dangerous for a car that is not supported by meth. He got away with it this time but it could as well have ended up in another Enrico' case since he has been using the car like this for some time. |
07-09-2010, 02:12 AM | #6 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
07-09-2010, 02:22 AM | #7 | |
56
Rep 1,311
07-09-2010, 05:19 AM | #8 |
57
Rep 1,054
07-09-2010, 12:20 PM | #10 |
1737
Rep 17,960
Drives: A Lot
The overboost trigger for valet is 1psi above the max boost value for a period longer than the user adjustable delay value. Unless either value is increases by the user, a prolonged overboost situation isn't possible.
07-09-2010, 07:56 PM | #11 | |
52
Rep 811
Coming soon? Sounds like it should have been there from the get go. No disrespect, but if you're going to let people update their own firmware there should have been a checksum verification in there all along. Wow, that's kind of scary. Good catch R1000K3
'08 TiAg E90 335 M-Aero kit. - SOLD
