      07-07-2010, 09:23 PM   #1
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
Why is my 0-60 so slow : (
I got 7.3 seconds! I am on auto transmission. Should i turn off all traction control completely?
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      07-07-2010, 09:31 PM   #2
BMWfan69
Drives: 2011 128i Coupe, AW/Terracotta
put it in sport mode
      07-07-2010, 09:31 PM   #3
Greenkirby21
Vrooom :)
it was in sport mode!
      07-07-2010, 09:46 PM   #4
ErvGotti
124
Drives: 2008 135i 6MT
2008 135i  [6.00]
Upgrade to a 135i
      07-07-2010, 09:49 PM   #5
Greenkirby21
Vrooom :)
Originally Posted by ErvGotti View Post
Upgrade to a 135i
lol if I had the money then I would
      07-07-2010, 09:51 PM   #6
dragon1761
dragon1761's Avatar
Drives: 128i SGM 08; 328i AW 14
you need to shift to 2nd gear to get faster speed increase after 5k rpm on 1st. Your gas is just revving the engine on 1st. Its not converting to work.
      07-07-2010, 10:10 PM   #7
Greenkirby21
Vrooom :)
sorry for this noob question, but if I leave it in Sport Mode will it auto shift at the best moment compared if to when I put it into tiptronic mode?
      07-07-2010, 10:22 PM   #8
Alex_bm
175
Drives: Giulia QV
I tried in both modes, and shifting manually in couple different ways, and ..... unfortunately that's what you get with a combination of an auto transmission and N52 engine.
How many miles did you put on this car?
The reason I ask is because you will notice slight difference in performance after a full breakin.
      07-07-2010, 10:24 PM   #9
Greenkirby21
Vrooom :)
I have around 14,000 miles
      07-07-2010, 10:30 PM   #10
chylld
chylld's Avatar
54
Drives: G08 iX3
7.3 is better than what I managed with my BMS-tuned 125i
      07-07-2010, 11:32 PM   #11
Greenkirby21
Vrooom :)
I am going to turn off all traction control, and leave it in sport mode and see what that does. Is there a way to quick start automatics? I know rev in neutral then dump it into D but I heard that is very bad. I tried holding the brakes and pressing da gas but it only went to 1.5 rpm. I heard something else you could do with hand brake? I just dont want to damage my car xD
      07-07-2010, 11:35 PM   #12
chylld
chylld's Avatar
54
Drives: G08 iX3
Holding down the brake I think I revved to about 2k rpm and then released the brake while gradually applying more and more gas. I read that this is the fastest way to launch a slushbox (rpm may vary) but I didn't get consistently better results than just launching normally (lift off brake completely then floor gas)
      07-08-2010, 06:36 AM   #13
B_2_B_P
B_2_B_P's Avatar
Germany
18
Drives: 128i Sport /w PDC and ComAcc
2009 128i  [0.00]
What are you using to track your 0-60 time and what should you use to track your time? 2 part question
Black Badge - Hankook Ventus V12 evo K110 18" - ASA AR1 18" - B&M Short Shifter - aFe Stage 2 CAI Pro 5 R - Gloss Black Kidney Grills - Performance Pedal Kit - CDV delete - Custom Tint - Bastuck Exhaust w/o Silencer - Custom Tune
      07-08-2010, 08:30 PM   #14
K03sport
K03sport's Avatar
Drives: Silver GTI, yeah I know...
Also, was the car fully laden? How much gas was in the tank? Was there a head wind? The list could go on...
Did you air down your rear tires any?
What are you hoping to achieve...sub 7 second and why is it so important?
No Signature yet.
      07-08-2010, 08:40 PM   #15
chylld
chylld's Avatar
54
Drives: G08 iX3
assume these questions are directed at the OP, but i'll answer them for my own car first...
1) dynolicious (iphone app) and stopwatch
2) should use a g-tech
3) car only had me in it (i weigh 160lb)
4) 1/4 tank gas
5) no wind
6) rear tyres slightly under recommended pressure
      07-09-2010, 12:15 AM   #16
B_2_B_P
B_2_B_P's Avatar
Germany
18
2009 128i  [0.00]
http://www.gtechpro.com/ss.html#
Seriously? This can read all that including HP and Torque from the cig lighter? Any one have this? Is it accurate?
      07-09-2010, 12:37 PM   #17
tWinTuRboz
Freshman RaceR
8
Drives: BeEMeR 135i
I dont think revving in neutral then shifting to drive is going to do anything for you. traditionally what i do is just kill the traction control by holding down the dtc button til the alert triangle comes then pop it into sports mode, hold down the brakes and then gas it up to around 3k. Then let go of the brake. That way, you can do the whole burnout effect too. ps. hands on the ten and two oclock positions
      07-09-2010, 10:06 PM   #18
Yuzi
Yuzi's Avatar
12
Drives: BMW 128i
try again with
-DTC on
-one foot on the brake one foot on throttle and launch at 2k
-shifting at 6k instead of shifting at redline
Currently driving 2003 HONDA S2000
128i | Jet Black | Premium package | Sport package | 18" Style 263 | 6MT | Injen Intake | BMS PowerBox |SOLD
      07-09-2010, 11:00 PM   #19
dragon1761
dragon1761's Avatar
start at 2nd gear. That would increase the speed of 0-60. i tested it today
      07-09-2010, 11:30 PM   #20
Lucky1
640
Drives: '08 128i Coupe SGM 6MT
How fast do you think it should be? I'm pretty sure BMW used to quote 0-60mph for the auto in 7.0, you aren't far behind. The automatic on the 128i isn't as good as the 135i. Also, are you using precise instrumentation for testing your time?
The bmwusa.com website indicates 6.1s/6.7s manual/auto.
I'm pretty sure those aren't the original numbers they put out when the car was released.
      07-09-2010, 11:46 PM   #21
Yvette
759
Drives: M
we can't expect too much from 128i can't we.....
      07-10-2010, 12:26 AM   #22
dragon1761
dragon1761's Avatar
its not what you have. Its how you drive your car that counts.
Search this Thread:
Advanced Search
