3rd half-engine light in 3 months
07-07-2010, 05:49 AM | #1 |
21
Rep 591
6:00am this morning driving around 45mph the reduced power, 1/2 engine light appears....again.... I haven't even put on 500 miles since my last 1/2 engine light The 1st time the dealer said it was a "sensor" The next time it needed a software update... and now what???? Do I finally get a new HPFP???? or do I have to put up with this bullshit until I sell this thing? Does the new 335 have these problems? How about the New Z435i? This is just getting a little absurd already
2007 E92 Metallic Black, Black interior, brushed aluminum, 6MT, Nav, 6FL, 20% ceramic tints, OEM Front Lip, Dinan Stage 2 Rev2, 19''s M6 Reps Last edited by canesr1; 07-07-2010 at 07:10 AM.. |
07-07-2010, 06:13 AM | #2 |
161
Rep 7,377
would be great if you could check what codes you are getting. i would go to a good mechanic shop able to read codes and check them out . if it is the pump just get them to replace it and forget about the dealership.
07-07-2010, 08:28 AM | #3 |
133
Rep 4,764
+1 - What does your Dinan dealer think about it? Can you bring the car by their place to find out what the codes are?
07-07-2010, 08:40 AM | #4 | |
21
Rep 591
The codes on my work order last time(2nd time in) were "30ff and 2A22, not related", 2A22 not present- ignore" ---Any clue what this means??? Not sure what codes were thrown the 1st time.
2007 E92 Metallic Black, Black interior, brushed aluminum, 6MT, Nav, 6FL, 20% ceramic tints, OEM Front Lip, Dinan Stage 2 Rev2, 19''s M6 Reps |
07-07-2010, 08:55 AM | #5 |
133
Rep 4,764
Not a fan and don't trust the dealer service/maintenance shops.
If you plan to keep the car a while, get a Bavarian Technique tool and see the codes first hand for about $300. Then buy the Bentley manual for $82 of Amazon. Sounds like you are frustrated, but I would be extremely frustrated dealing with the dealer service department. I feel most of them are full of it! There are some great BMW techs out there, but the service department is run as a huge profit center. Customers come last IMHO. |
07-07-2010, 08:58 AM | #6 |
133
Rep 4,764
30ff is an underboost code.
Who knows if those are really the only codes, maybe you had a 2aaf (fuel pump)? There is another thread where someone had the 2a22 with the 2aaf. |
07-07-2010, 09:04 AM | #7 |
133
Rep 4,764
2a22 - has something to do with a reservoir fill. Interesting that another Dinan tuned car kept getting that 2a22 code: http://www.n54tech.com/forums/showth...highlight=2a22
07-07-2010, 09:07 AM | #8 |
133
Rep 4,764
30ff - Terry has said, "30FF = boost leak or wastegate issue. Also possible vacuum line issue around boost solenoids or DV."
http://www.n54tech.com/forums/showth...highlight=30ff You could have a small boost leak in the system. |
07-07-2010, 09:29 AM | #9 | |
21
Rep 591
It also says "found older software installed, refer to sib 12-28-07" I'm going to start looking for a new ride. I can't be driving a $50k car that is less reliable than my $10k jeep wrangler... especially when NOONE at BMW knows their ass from their elbow it seems.
07-07-2010, 10:07 AM | #10 | |
21
Rep 591
This is really bizarre... the light is off now and hasn't gone back on yet and car is driving normal. It may be time to take a look at the S5
07-07-2010, 11:03 AM | #11 |
133
Rep 4,764
Check this out. Guy had wastegate + turbo issues. Ask your dealer to check them out. Maybe print out this post:
http://www.e90post.com/forums/showth...highlight=30ff They probably don't like doing the procedure due to the labor to get them out and do the measurements. |
07-07-2010, 11:08 AM | #12 | |
21
Rep 591
Thanks again dude. I will print that out and give it to the SA on monday.
07-07-2010, 11:20 AM | #13 |
133
Rep 4,764
Another persone where the wastegate hardware needed adjustment:
http://www.e90post.com/forums/showpo...1&postcount=37 |
07-07-2010, 03:08 PM | #14 |
21
Rep 591
I just went for another drive and within 8 miles I got it again. This time it said "reduced engine power, safe to drive".
I turned it off and back on and it was gone. Drove about 15 miles more and nothing...everything is ok again!
07-15-2010, 05:45 PM | #15 |
21
Rep 591
Car has been in since monday with the same exact codes as last time which was less than 500 miles ago. I'm not sure how long it will be in this time but I don't anticipate getting it back until next week at the soonest... then I will probably sell it. I don't have time for this BS anymore. This is my 6th BMW and by far the one with the most problems. I can't have a $50k car that is less reliable than my '05 jeep wrangler.
What's the longest your cars have been in service for????
