BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Dyno results - 396.7 tq @ 2900 & 365.5 hp
      07-06-2010, 07:16 AM   #1
E90MTL
20
Drives: '07 E90
Exclamation Dyno results - 431.2 tq @ 2900 & 368.6 hp
16/10/2010 NEW RUNS - Differences:
Same mods as before - Just new map (Autotune)
Autotune Enabled, Agression=2
And No Octane Enhancer
TQ 431.2 @ 2784 rpm --> 12.88 psi
HP 368.6 @ 5750 rpm --> 13.64 psi
Steady 57 deg F Ambient.
relative Humidity 34%
this is only a screen shot of some of the 25+ runs we did.
2007 E90 335i
6AT
Vishnu Procede V4 non-autotune.
Map 2, 2+
Helix FMIC
AFE DCI
Britalman Exhaust
94 Octane + 2 bottls of NOS octane enhancer for good measure. LOL.
4/6/2010
TQ 396.7 @ 2912 rpm --> 13.34 psi --> 11.92 AFR
HP 365.5 @ 5752 rpm --> 11.48 psi --> 13.69 AFR
Steady 99.9 / 100 deg F Ambient.
So... after a few months of enjoying my tune and some bolt ons... I figured it was time to set a few "baseline" runs, before I tune it more.
I went to Dynodoc - www.dynodoc.ca - Brady Moffat (info@dynodoc.ca). Brady was very friendly and enthusiastic, I would reccomend Him and his shop for all forms of Engine Tunning. (514) 396-9390
6565, ave Durocher
Montreal Quebec H2V3Z4
E90 2007 335i, AW, 6AT/Step, Proceed V4, AFE CAI, Helix FMIC, Britalman Exhaust, 94oct all the time. Dyno - 433tq @ the wheel (Pump gas and stock DP's)
Per vox illic est haud terminus
      07-06-2010, 07:47 AM   #2
lyndon_h
lyndon_h's Avatar
40
Drives: e90
Nice numbers, especially for the temp. I didn't know that Montreal got so hot!
      07-06-2010, 07:54 AM   #3
E90MTL
20
Drives: '07 E90
we have a wicket heat wave... it's bloody ridiculous.
      07-06-2010, 07:59 AM   #4
Irishace
ElevenPointFive
Irishace's Avatar
326
Drives: E90 335
Good numbers!
2008 E90 335xi - N54 Daily Driver
MHD Stage 2+ ~ CPE DPs ~ BMS Intake ~ AMS FMIC
      07-06-2010, 08:28 AM   #5
zeenon53
zeenon53's Avatar
39
Drives: BMW
Very nice. I've never seen a dyno like that before.
      07-06-2010, 08:38 AM   #6
luv135i
luv135i's Avatar
60
Drives: White
Dynopacks are good...just tend to read a lil high due to not having to turn any rotating mass.
      07-06-2010, 11:48 AM   #7
ar design
ar design's Avatar
Drives: 04 M3
Very nice! Time for some methanol and downpipes!
      07-06-2010, 12:10 PM   #8
OpenFlash
Drives: A Lot
They tend to read a few % higher than other load bearing dynes (mustang, dyno dynamics, etc. But still lower than Dynojets which are universally regarded as the most optimistic. This is assuming standard calibration of course which is why a stock/valet baseline run is useful. Good results though, good-looking car as well!
But definitely update to the autotuning maps. You will probably find out that you left a lot on the table with the early maps at default settings.
Shiv
      07-06-2010, 03:10 PM   #9
E90MTL
20
Drives: '07 E90
Andrew.... I loved the Helix FMIC I got from you.. too bad I had to sell your catless DP's during winter to make a car payment. all is good now. DP's are still up in the air.. I won't cheap out for the VK's or raceland.. I want AR only... but don't have the spare $$.
Shiv, you just emailed me the link to the autotuning maps... thanks. If i send you the CSV file with the AFR's and PSI.. (didn't Procede data log this time) can you just give it a once over for sanity check. The tuner said it was dumping a lot of fuel.. and running a lot leaner higher up would be much better....
      07-06-2010, 03:17 PM   #10
OpenFlash
Drives: A Lot
Yep..email it over. It's very unlikely that the car was running too rich up top. It should run around 11:1 up top which is on the rich side. But it's certainly not too rich by any means. Maybe the tuner is used to traditional naturally aspirated engines in which case 11:1 is too rich for sure.
Also, in your dyno results, what is the low 250whp run? Valet? Stock?
Shiv
      07-06-2010, 03:58 PM   #11
E90MTL
20
Drives: '07 E90
Shiv,
All info sent to your email. Thank you for your personal dedication to Customer service.
Going beyond standard product support has won me as a lifelong client.
      07-06-2010, 04:16 PM   #12
dzenno
273
Drives:
you might be running richer than usual if you have a boost leak...
      07-06-2010, 04:36 PM   #13
OpenFlash
Drives: A Lot
Shiv,
No problem. I saw your txt file that had the AFR values. Looks perfectly solid. ~11.5:1 at peak hp. Not too rich by any means.
Shiv
      07-06-2010, 09:46 PM   #14
BOOSTED4DR
29
Drives: 07 335i
nice #s
      07-06-2010, 10:27 PM   #15
Fernflex
Fernflex's Avatar
Puerto Rico
48
Drives: E92 Crimson Red 335i
Nice numbers, I got simillars numbers but I dont have exhaust and I was running 93 octane.
375whp and 393tq
Jb3 2.0
BMS DCI
Helix Fmic
VK 2.5 catless dp's
Caribbean weather and 100% humidity
And my car feels great you must be happy!
R56 Cooper S
E92 335i
E30 332is
Burger Tuning, Evolution Racewerks and VRFS in Puerto Rico...
      07-07-2010, 08:38 AM   #16
E90MTL
20
Drives: '07 E90
OK so.. with 3" dp's I should definetly be in the +415tq and ~400HP club with autotuning on and 94octane.. hmmmm Race gass will be fun. will I need DV's now?
375whp and 393tq
Jb3 2.0
BMS DCI
Helix Fmic
VK 2.5 catless dp's
      07-07-2010, 08:55 PM   #17
kennejp
39
Drives: 335i
With the autotune would you be running more boost? Boost levels seem a little low for your mods?
      07-08-2010, 09:18 AM   #18
Fernflex
Fernflex's Avatar
Puerto Rico
48
You can use your stock dv's but you maybe loosing boost, Dp's helps a lotttt, im removing my 2.5 and installing 3''
R56 Cooper S
E92 335i
E30 332is
      11-03-2010, 01:58 PM   #19
E90MTL
20
Drives: '07 E90
bump - NEW RUNS
      11-03-2010, 02:36 PM   #20
DefactoM6
Sees the world the way it could be
Drives: '88 M6, '02 Z8, '09 E92 335i
So let me get this straight... you basically de-modded, ran current maps and got the same power? If so...nice!
      11-03-2010, 02:39 PM   #21
E90MTL
20
Drives: '07 E90
All I did was update to Autotune maps. And I didn't bother with the octane booster.
      11-04-2010, 01:21 PM   #22
dc5_champ88
dc5_champ88's Avatar
24
Drives: 2007 BMW 335i
2007 BMW 335i  [0.00]
siiick #'s!!
