Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > RFTs - Bubble Issue. How Big a Problem?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      12-21-2006, 02:05 PM   #1
Casey 5
8
Drives: E90 335i,SPG,ZSP,ZPP,Step
How many of you have experience an unexplained bubble in the sidewall of your RFT requiring replacement of your RFT?
By "unexplained" I mean that you were not involved in an accident nor do you recall an unusal impact or trauma to the tire. In other words you only recall normal "performance" driving conditions within the type the tire should be designed to function without failing.
I have experienced a bubble on the 18' RFT that was mounted to the 162 rim that came with the 330i I purchased back in June 2005. After 6000 miles that tire developed a bubble. THe 162 rim was pristine and the tire had experience no trauma other than regular performance driving.
I am now hearing that others have had this bubble issue on their 18's and some have had it on their 17s.
It may potentially be the case that these RFTs have a design or manufacturing problem and should be recalled. A recall would require the manufacturer to replace all Bubble tires free of charge.
      12-21-2006, 02:12 PM   #2
obLu
obLu's Avatar
50
Drives: 330i 6MT ZSP
I got one. Surprisingly it's not on my wheel that took a beating in a pot hole .... it was bad enough to rash my wheel but the tire's fine.
But I'm not making a big deal about it. It's runflat right? Most incredible technology ever, can't possibly have a blow out ... so what's there to worry about?
      12-21-2006, 02:18 PM   #3
petesamprs
petesamprs's Avatar
Drives: .
i have a very small, barely noticeable bubble on my winter RFT. Cause unknown. I'm gonna run it for the rest of the season and see if it gets worse.
'14 535i (ED)
Retired: '08 M5, '08 550i (ED), '06 330i
      12-21-2006, 02:18 PM   #4
Casey 5
8
If there was nothing to worry about...it would not need to be replaced. I think there is a potential safety issue with the bubble...otherwise they would advise to keep in service.
      12-21-2006, 02:21 PM   #5
obLu
obLu's Avatar
50
It was sarcasm.
      12-21-2006, 02:22 PM   #6
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
Casey, I think obLu was being facetious.
When you guys say a "small" bubble - what does that look like?
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
      12-21-2006, 02:23 PM   #7
Richwm
Richwm's Avatar
Drives: 06 E90 330i 6MT, 01 E46 330i
how about a picture so we can see what you are talking about.
Mar 05 Build date,2006 E90 330i, Sport Package, Premium Package, TR MT-1's . V-1 Hard-wired power with custom V-1 Concealment Display . Rear fogs, Rear power outlet's, M short shifter knob, BlackLines, BMW Strut tower bar, CDV Delete, Front M3 wishbones + tension struts, BMW Performance shocks and springs, BMW Performance Brake kit F&R, OEM short shift kit. Rear M3 Guide rods and Wishbones.
2006 E-90 330i with 302,000 miles.
      12-21-2006, 02:29 PM   #8
obLu
obLu's Avatar
50
It's not so much a traditional bubble like you used to see. Traditional bubble looks like a big ole bloated wart on your sidewall. I think it was from seperation of belts? I dunno. Been the mid 80's since I had a cheap ass tire that got one.
The RFT bubble I've got looks more like two internal belts overlapping each other and creating a bulge. But that bulge has gotten bigger and bigger over time, and none of my other tires exhibit it.
I was half serious when I said I don't care. I've experienced a couple of freeway speed blowouts in my years and they're nothing to be afraid of unless you overreact. I'd almost welcome it blowing so I could then completely dismiss RFT as useless tech.
      12-21-2006, 02:29 PM   #9
Casey 5
8
Unfortunately I replaced mine last summer and did not take a picture...just kept the service paperwork.
      12-21-2006, 09:08 PM   #10
SuperSport
SuperSport's Avatar
Drives: '20 X3MC, '16 Cayenne S
2006 330i  [0.00]
Here is the thread I started about my issue, with pics
http://www.e90post.com/forums/showthread.php?t=40451
'20 X3MC -Bm3 Stg1 91, dragy 11.10@124.91 (0-60 3.20),'16 Cayenne S - Sold,
      12-21-2006, 11:02 PM   #11
BK
Smiling politely
Drives: 330i
2006 330i  [9.00]
Thanks - that is very helpful and I'll keep an eye out for it on mine (so far so good, knock on wood).
      12-21-2006, 11:20 PM   #12
SuperSport
SuperSport's Avatar
2006 330i  [0.00]
My car was purchased in Oct. of 05, so what I am wondering if this RFT issue is happening more of the first sets produced for the e90's or if it a cause of concern for all of the RE050A RFT.
SIDE NOTE.
I talked to a Manager at a Bridgestone dealer today, and I "quote" he said that the so-called impact seperation they are saying it is
"Could be caused by as little as pulling into your driveway"
So then I replied "what's the point of having tires you can't drive on without catastrophic failure, for everyday drving situations. Sounds to me like poor quality tires"
      05-23-2007, 11:46 AM   #13
curvehound
42
Drives: 2016 MG/SO M3
bubble fixed with tire warranty
I have a E90 with the 18in wheel package (bridgestone RFT's). the tires have about 7k miles on them and the two fronts both have large bubbles in the sidewalls. I bought the tire/wheel warranty package from the dealer when i bought the car. Anybody have any luck getting their warranty to cover replacment of tires for bubble problems? the dealer says the wheels need to be replaced and that the bubbles are due to road damage but says the warranty does not cover this problem.
thanks
Ian
