Run flat indicators on non RFT's
12-21-2006, 09:45 AM | #1 |
44
Rep 749
I have a set of 18's for winter on non RFT Blizzaks. Can you install RFT inticators in them so you will be alarmed of tire preasure etc?
How does the whole RFT indicator work. I know search search, bla bla. here is a funny pic for your troubles.
Sapphireschawarz E90 335 /// Sports Package /// Terra-Dakota-Aluminium /// Comfort Access /// Steptronic-Paddles /// Discharged in Halifax
12-21-2006, 09:53 AM | #2 |
Smiling politely
165
Rep 7,931
You have an E90, so the flat tire monitor, which works off your ABS system, will work for both RFT and non-RFT tires.
Is the photo real or Photoshop?
E90 330i Black Sapphire 6MT | 991.1 C4 Platinum Silver 7MT
12-21-2006, 10:32 AM | #4 |
Larry from Los Angeles
14
Rep 296
The tire pressure monitoring system on the 2006 BMW 3 Series, and I believe the 2007, also, is really rather low tech and works with all tires and wheels.
The car merely monitors the relative rotational speed of all four tires. When one of the tires rotation differs from the other tires, the computer treats this as a flat tire because tires with less air have a different size (less inflation changes the size of the tire) than the other tires and rotates at a different speed. That's when the warning lights up on the dash. When cars have real monitoring systems that actually are CONNECTED to the tire, itself, and give an actual PRESSURE READING, then the wheels are going to have to be capable of connecting to the car's computer system. Some cars have this system. But, it is my understanding the 3 series does NOT have this system yet. Hope this helps. Larry P.S. I removed my RFT and have Pirelli Nero P-Zero regular tires and the car is now fantastic. |
12-21-2006, 10:46 AM | #5 |
JetInsp
12
Rep 289
Easy way to know what system you have is to look at the valve stems. If you have rubber (flexible) valve stem you don't have the sensor in the wheel.If the valve stem is rigid then you do have the sensor in the wheel.
12-21-2006, 10:48 AM | #6 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Yes as others have chimed, the US spec MY06 E90s have a simple Flat Tire Monitoring (FTM) system not an active Tire Pressure Monitoring System (TPMS).
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
12-21-2006, 10:53 AM | #7 |
Smiling politely
165
Rep 7,931
And to fill out KL2DC's thought above, the E92 has the TPMS.
12-21-2006, 11:03 AM | #8 | |
Moderator
318
Rep 17,767
12-21-2006, 11:07 AM | #9 | |
Eight Bimmers and counting
35
Rep 761
I have the indirect system on my M5, and it works reasonably well. When I had a slow leak (bent wheel), it did a good job of screaming before the tire got low enough to do damage. (The compressor in the ///M Mobility Kit was invaluable -- I could add air regardless of where I was at the time.) I'm thinking about doing the same as you -- putting non-RFTs on the 335 for winter tires. I am, however, considering buying a mobility kit for the car, so I'll have the compressor and tire goop if needed.
2014 F10 M5
Previously... Threes: '08 E90 M3, '07 E92 335i, Fives: '11 F10 550i, '02 E39 M5, '00 E39 540i/6, '97 E39 528i, '92 E34 525i Others: VW, MBz, Peugeot, Toyota, Olds |
12-21-2006, 11:10 AM | #10 | |
Smiling politely
165
Rep 7,931
12-21-2006, 11:20 AM | #11 | |
Moderator
318
Rep 17,767
Oh ok, thought I read it somewhere
12-21-2006, 01:15 PM | #12 |
Rep 106
I have a 2007 E92 (328i) with runflats and the TPMS is in the wheel. The valve stem is metal.
12-21-2006, 02:52 PM | #13 |
54
Rep 2,469
Drives: 2006 E90
What if I install the wheels from E92 (335i with TPMS) to my E90 (330i), would the TPMS work in my 330i indirect system or do I need to upgrade the software as well?
2006 BMW 330i - Delivered 9/16/06
Black Sapphire | Terra + Poplar | Sport | Premium | PDC Blacklines | 189 Wheels | CF Front Lips | Euro Headlights | Rear Fog Lights |
12-21-2006, 03:20 PM | #14 | |
Smiling politely
165
Rep 7,931
FTM will continue to work with those tires on your E90, though, so IMO it's no big deal. I've heard (on other cars) of more problems with the TPMS-type systems than the FTM-type systems, anyway.
12-21-2006, 04:29 PM | #15 | |
Rep 106
Originally Posted by misterng:
"What if I install the wheels from E92 (335i with TPMS) to my E90 (330i), would the TPMS work in my 330i indirect system or do I need to upgrade the software as well?" Quote:
12-21-2006, 05:50 PM | #16 | |
9
Rep 141
I use runflats full time on my E90 but I also carry an M Mobility System . My reason is that, in Canada at least, there are places where you can get a flat and the nearest replacements are out of the recommended driving range with damaged runflats. I reckon that if a leaking runflat can be sealed, it can be driven much longer distances, maybe indefinitely (and at higher speeds) in order to get to an independent tire dealer or BMW dealer that carries replacements. The reason of course is that a tire containing air pressure does not stress the sidewalls as much as flat tire does. Fortunately, I do probably 95% of my driving within range of a dealership so I will probably never need the M-mobility but I have had flats in previous cars in locations where I would have been in trouble with runflats. In my humble opinion, the external pressure monitoring system (as used on the E90) is a much better idea than the system that attaches to the valve. I'll bet that BMW changed not because they wanted to but because they had to in order to comply with US regulations. |
12-21-2006, 06:00 PM | #17 | |
15
Rep 106
12-21-2006, 09:08 PM | #18 | ||
35
Rep 761
1. Winter tread/compound 2. Run-flat 3. V speed rated I had H-rated winter tires on the 540i/6 that preceded my M5, and I hated driving the car with them. It was fine in crummy weather, but the performance was WAY worse than what I was accustomed to in dry weather. Has anybody got any suggestions for a tire that meets all three requirements?
2014 F10 M5
12-21-2006, 11:17 PM | #19 | |
Smiling politely
165
Rep 7,931
FWIW, I'm running Dunlop M3 DSST RFTs, which are H speed rated, and you're right that the performance is a noticeable drop-off from the summer tires on dry pavement. They just aren't quite as "confidence-inspiring" through corners as the stock summer tires. But I figured that was a result of the tread, smaller rims, and thinner rear tires, not so much the speed rating. 130mph (H) should be enough, shouldn't it? V is 150mph. It's not like I'm driving anywhere close to 130mph anyway. That said, I can't complain much about dry performance of the Dunlops. Have you tried them? They're pretty good, it's just that sometimes they just feel like they are about to skip over the pavement through a turn rather than stick to it. But so far, they've stuck. They are winter tires, after all, so my expectations were relatively low and IMO they're better than I expected. Not as loud as I thought they'd be, and in general they seem comfortable at any speed. I can't imagine that a V rating would make them much better. Then again, I'm driving a 330i and not an M5.
12-22-2006, 06:08 AM | #20 | |
9
Rep 141
When I bought my car last year, there were only two manufacturers producing winter RFTs for the E90 that were available locally. Bridgestone (Blizzak) and Pirelli (Sotto Zero) so the choice was limited. I think Contis were available in Europe. I got the Bridgestones by default, the Pirellis were out of stock at the distributor at the time. The story I heard was that when BMW decided to specify RFTs as standard, they had to commission Bridgestone to make them tires, probably because the development costs would not otherwise make it worth a tire manufacturers while to cater to the tiny market that BMW represents. If true, Bridgestone probably worked probably worked fairly closely with BMW on the technical requirements for their tires. I seem to recall that the only cars before BMW with OEM runflats were the Corvette and the Honda Oddessy. |
12-25-2006, 01:41 PM | #21 |
51
Rep 383
I have a 2007 bmw 323i, and in the manual it says that TPM is inactive if you have wheels without TPM electronic... Does that mean i have direct TPM?
12-25-2006, 03:37 PM | #22 | |
45
Rep 1,738
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red 2007 Chev Silverado crew cab Z71 |
