Mobility Kits
12-21-2006, 05:46 AM | #1 |
Rep 32
Mobility Kits
Anybody used one of those tyre mobility kits after replacing the standard RFT's and then getting a puncture?
Who makes the best kit? Cheers
[2006 e90 330i, Titanium, 18" Tech MV-2's, Bridgestone non-RFT S-03's, Koni Sport Dampers, Lowered 30mm with Koni Sport Springs]
12-21-2006, 10:43 AM | #2 |
Larry from Los Angeles
14
Rep 296
I put regular Pirelli tires on my car. I bought a $50 inflator at Sears (It works in the car and you set the pressure and it stops when it reaches that pressure. It is made for vehicles up to SUV and pickups, so it inflates very quickly and has a fan to keep it cool, so it doesn't shut off prematurely.)
I bought a can of Pennzoil Tire Sealant. I got the 16 oz. size. I put them both under the truck lid in the little storage place below the hard cover. So, if I get a puncture, I will first try to inflate it WITHOUT the sealant, and if the air still comes out, I will pump in the sealant. If there is a catastrophic failure, I will flatbed the car to the dealer. This is precisely what I would have to do with such a failure in a RFT. There is no difference with RFT or Non-RFT with a complete tire failure. The only benefit of a RFT is that in a puncture situation, you don't have to stop and put in air. However, if you drive the RFT any distance, the manufacturer says you should replace the tire and not repair it, because driving more than a mile or two (I believe) compromises the stiffness of the sidewalls and defeats the run flat capability of the tire for the future. L |
12-21-2006, 03:29 PM | #3 |
10
Rep 153
I too have RFT on my 335i coupe and was considering changing to Goodyear F1's. I remember reading somewhere that if you remove the RFT and have a tire issue, BMW Roadside will NOT help you. Anyone know if this is true?
I can see the logic from their perspective, but I'm hoping this is |
12-21-2006, 03:57 PM | #4 |
Rep 9
I ordered the Continental Conticomfort kit with my non-rflts.. Seems pretty legit, and not too much $$.
http://www.tirerack.com/accessories/...tkit/index.jsp |
12-21-2006, 04:02 PM | #5 |
50
Rep 1,159
You can also add towing to your auto insurance policy very cheaply. I think on our's it's $1.50 a month for all the cars under our policy.
But as far as BMW Roadside, it's farmed out. They don't have a clue if you've got RFTs on or not. Only reason they know to answer as BMW is because the call comes into that queue. Last time I had to use BMW Roadside the first truck that showed up was a sling. When I refused that one and called back the second truck that showed up was a flatbed but the driver REFUSED to pull the car up using the tow hook. Even showed him the manual several times! He wanted to put a hook around the front suspension arms and yank it up that way .... that've been wonderful for the bushings. So I sent that guy away and called private. Called BMWNA and they couldn't have cared less. Point is, don't worry about if BMW Roadside is going to cover you; chances are it'll be worthless anyway. PS. I plan on ordering the Continental kit too. |
12-21-2006, 06:07 PM | #6 | |
21
Rep 574
12-21-2006, 06:35 PM | #7 |
31
Rep 746
Drives: 2007 328 Coupe Alpine White
I bought one of these.
http://www.slime.com/smartspairs/index.php Slime is cheap to replace as well. The refill for a mbility kit (BMW's) is like $40 |
12-21-2006, 07:47 PM | #8 |
10
Rep 153
What about the $2.49 can of fix-a-flat I remember from 10 years ago. Won't that work? I have the 335i with the neat metal valve stems(tire pressure sensor). I don't want to damage that. Is the only safe thing the M or Continental Mobility kits? The Slime site says to remove the valve stem???(Hopefully misread that)
I can buy a 120psi compressor for $70 with a plug kit for $20. Will the fix-a-flat stuff ruin the tire pressure sensor or rim? I'm probably not running out to change the RFT tonight, but will most likely replace them with non-RFT when they wear down to the minimum lease turn in tread line and garage them for another two years so I'm trying to get as much info as possible. |
12-21-2006, 11:12 PM | #9 | |
Rep 153
06 330i // Silver // Step // Prem // Sport // IDrive // OEM rear lip // LLumar Tint 35%(f), 20%(r) // HRE 448R-silver // 19x8.5(f) & 19x9.5(r) // Goodyear F1s, 235(f) & 265(R)
12-21-2006, 11:36 PM | #10 | |
21
Rep 574
standalone compressor plug kit + compressor sealant + compressor edit: oops, sorry. you already heard me say this from the other threads. |
12-22-2006, 12:07 AM | #11 |
Rep 32
Thanks for all the replies.
I'm looking at getting this for US$100. Seems pretty comprehensive. http://www.stopngo.com/auto.asp I'll also by a bottle of tyre sealant as back-up.
