N55 High-Flow direct replacement air filter
07-01-2010, 03:37 AM | #1 |
Supreme Allied Commander
3843
Rep 54,376
Drives: F80 M3
Our high-flow air filter for the N55 is ready for in car testing.
Here is the top and bottom view of the filter. Why Foam Is Better The principles of how foam air filters work is simple: "Open Cell" Polyurethane Foam is wetted with specially developed filter oil. The "sticky" filter oil is suspended in the path of the dirty air on the strands of the web-like cell structure of the foam. This makes it impossible for dirt to pass through the depth of the filter without sticking to the strands. As the outer strands become loaded with dirt particles, the wetted strands down stream start trapping dirt, allowing the entire thinkness to be utilized. This prevents surface loading or air restriction for 80% of the service life of the air filter element. When the air filter is sufficiently dirty. It can be easily washed, re-oiled, and re-used. Below is an independent dyno results by "FrankiE90" and a link if you guys want to read the full independent review: http://www.e90post.com/forums/showpo...53&postcount=1 Last edited by HP Autosport; 08-16-2010 at 02:23 PM.. |
07-01-2010, 03:50 AM | #2 |
313
Rep 3,262
The problem is, BMS showed a 30whp drop when dynoing the car with the air filter removed. This is because the way N55 measures air via a MAF sensor. This means that a high flow filter is likely to be detrimental rather than beneficial to performance without a special MAF sensor calibration via electronics.
07-01-2010, 05:34 AM | #4 |
Lance Corporal
19
Rep 128
Having run oiled filters on several other cars with MAF sensors they also bring about another issue: the oil residue eventually builds up on the MAF sensor causing faulty readings.
Usually not too hard to fix but it means that for optimum performance you need to remove and very carefully clean the MAF sensor to remove the oil residue at some point for continued accuracy. I got to the point where I would clean the MAF sensor every oil change but it usually takes a good bit longer for problems to show up. Usually will manifest itself with reduced fuel economy, slightly reduced power, poor idle, and a MAF sensor code when it gets too coated in oil. |
07-01-2010, 07:56 AM | #5 | |
184
Rep 2,841
I am sure everyone has seen the pictures of our intercoolers and intake pipes that are completely covered in oil residue from crankcase blowby. There is far more oil contamination in the intake system from your own engine than there is from an oiled air filter. Have a look here for some actual measurable testing on this: http://www.knfilters.com/MAF/4MAFSensorVideo.htm http://www.knfilters.com/MAF/3MAFSensorVideo.htm http://www.knfilters.com/MAF/2MAFSensorVideo.htm Last edited by Ilma; 07-01-2010 at 08:04 AM.. |
07-01-2010, 08:28 AM | #6 | |
Lance Corporal
19
Rep 128
Thats's why when folks do custom blow thru MAF setups (after turbo) on built turbo cars (for when you want to retain the MAF low end drivability without the intake restriction) it is highly recommended that a catch can or air oil separator be used in order to prevent oil contamination of the MAF. Also, while I have experienced oil contamination post filter with K&N setups you're also comparing the K&N to an oiled foam filter. Last foam filter I used, on a rotated turbo setup on an STI, was very heavily oiled and I saw visible oil residue in the MAF tube which was right after the filter. On a side note, I don't think K&N's own testing on this subject should be considered the most unbiased. I have run several K&Ns in the past (Vette, WRX, STi) and have definitely had to clean the MAF sensor due to receiving MAF related error codes. I'm not saying it was a big deal. Contamination really didn't start to become a problem on the K&Ns (actually two K&Ns and one Injen filter) until over 10k miles or more of use after new or re-oiling. And it was very easy to clean, just remove the MAF, spray down generously with MAF or electronics cleaner, clean the housing and exposed areas (not hot wires or MAF components) with a q-tip and be on your way. |
07-01-2010, 10:43 AM | #7 |
184
Rep 2,841
On the N54 at least, the MAP sensors are just in front of the throttle body and also in the intake manifold........
Therefore further downstream than the air filter and subject to lots of oil contamination from the crankcase vapours. Besides, if you watched those videos I linked carefully, you would have noticed the comments about OEM's placing charcoal filters in the air box as a pollution control mechanism due to residual vapours migrating backwards into the intake system once the engine is shut down and making their way into the atmosphere via the the air filter/MAF sensor housing. MAF contamination is not as simple and straightforward as you think it is. It's always easy to blame the oiled air filters, but those videos show some compelling evidence that speaks otherwise and they base their conclusions on empirical testing. Hope you caught that bit about a burn off cycle on the thermistor at start up to help burn off contaminants from the MAF. |
07-01-2010, 11:26 AM | #8 |
Lance Corporal
19
Rep 128
Still working on the videos, I'm 8,000 miles from high speed internet for the time being. Hoping to finish them by tonight. I do have to call into question the fact that K&N is putting these out. That and the fact that when you search for MAF oil contamination the top links that come up are ones that are clearly sponsored by K&N.
The MAP sensors should be a non-issue. They simply measure pressure and shouldn't be very prone to oil contamination, if at all. MAP: Manifold Absolute Pressure and in order to measure the correct pressure it has to be in or near the manifold and post turbo, intercooler, etc. If it was anywhere else it would only sense a vacuum. Thing is I've actually seen the oil residue in the various MAF housings and on the inside of the filters and it wasn't engine oil. As for vapors coming back through the intake I'm sure that happens to a small extent when the engine is shut off but anytime the engine is running it is pulling air in under significant vaccuum. Now, on the other hand, even though I saw non-engine oil in the filter housings maybe that wasn't the actual contamination that my MAF sensors were experiencing. In that case then it would have to be increase in particulate matter that was making it through the filters. |
08-07-2010, 12:36 AM | #9 |
3843
Rep 54,376
Drives: F80 M3
Lots of MAF issues occur after people clean their filters and simply spray way too much oil on the filter element, more is not better in this case. When you can physically see the oil droplets, it's too much.
08-16-2010, 01:48 PM | #10 |
654
Rep 8,801
for those wondering dyno of the foam filter at the link.
335 N55 http://www.e90post.com/forums/showth...53#post7788253
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
08-16-2010, 02:43 PM | #11 |
30
Rep 1,748
Nice Dyno numbers...
HP Autowerks... this is Probably a silly question, but this filter should fit the air filter housing for the X5 right? It's the same engine... I'll take a look later today and see if the housing is the same... should be... If so, I'll be ordering this ASAP...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
09-09-2010, 08:03 PM | #12 |
16
Rep 420
Drives: 2011 e90 335 ix, 08 335i e92 6
trying to get an update from anyone else that have used this filter........any other reviews???
09-09-2010, 09:26 PM | #13 | |
3843
Rep 54,376
Drives: F80 M3
