Squeaky noise when turning right
06-30-2010, 09:14 PM | #1 |
19
Rep 113
Hi,
I got a squeaky noise that sounds like it is coming from the the front of the car when I am making a right turn, it's silent when I go straight or left. Kind of weird, I just got my brakes replaced for squealing. It's still under warranty, so I will take it in soon. Just want to check whether this is a common problem, if anybody has clue what it could be, and how quickly I should get that fixed. Thanks! |
06-30-2010, 09:32 PM | #2 |
40
Rep 720
are you talking about the metal shhhhhhhhh sound?
That's what I hear when turning all the way left or right.. didn't sound normal at all but dealer says it's normal... |
06-30-2010, 09:40 PM | #3 |
45
Rep 1,754
There's an SIB out on this -- SA is told to advise the customer to avoid right turns when possible until BMW comes up with a solution...
06-30-2010, 10:33 PM | #4 |
19
Rep 113
06-30-2010, 10:34 PM | #5 |
19
Rep 113
07-01-2010, 12:19 AM | #6 |
45
Rep 1,754
07-01-2010, 09:23 AM | #7 |
228i Fanatic
16
Rep 969
I would strongly encourage you to plot your route in advance using all left turns.
From the desk of the problem avoidance team. Last edited by hpowders; 07-01-2010 at 10:39 AM.. |
07-01-2010, 09:37 AM | #8 |
Rock Band Drummer
Rep 69
brake pads. dont let the service advisor tell you that its normal. its not.
most likely the inner pad is worn down unevenly and when you turn right, it pushes weight towards the left and you'll get noise. the service man will actually have to pull off the caliper and look at the pads. you cannot just eyeball it with the caliper on. |
07-02-2010, 05:38 AM | #11 |
19
Rep 113
The squeaky noise seems to be in synch in with the rotation of the tires, so my guess is also brake pads or wheel bearings. Since it could be brake pads, I will monitor it a couple more days and see if it goes away.
12-03-2010, 09:17 AM | #13 | |
67
Rep 2,189
ppp
Olds Starfire > Chevy Malibu > Isuzu I-mark RS & Honda Magna 500 > Grand Am GT & YSR50 > Nissan Maxima & Ninja 750 > X-Wife > Hyundai Excel > Honda Prelude > Honda Accord > Honda Prelude & Ninja 250> Infiniti G35 > E90 335i > Hyundai Genesis Rspec, Hyunadai Sonata > Kia Sorento > Honda CRV-EX |
12-08-2010, 08:50 PM | #15 |
19
Rep 113
Jokster are off the hook again here. Anyways, there was no real solution. The noise somewhat diminished over time, I am not sure if it went away completely, I don't drive with the windows open that much anymore due to weather here in NJ. I talked to a BMW rep once on the phone about it, and he pretty much told me to backup a couple of times at speed and then brake hard to clear up any break dust buildup that there may be. Not sure if that made a difference though.
12-08-2010, 09:17 PM | #18 |
253
Rep 7,089
Drives: '06 AW 330xi
I had a creak in my steering rack....dealer lubricated it and has not come back since. I had it checked out at about 42K....I'm at 60,500 now.
11-16-2011, 05:42 PM | #21 |
14
Rep 143
I'm getting this problem now, seems to only happen at low speeds turning right, probably amplified by being in a parking garage. Or maybe I just can't hear it when turning faster?
