Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > RD 7000k installed, got error.
      06-24-2010, 01:03 PM   #1
mkiv
2JZ
63
Drives: 16 G500
So i installed RD angeleye kit for my e92 and it works good. but i got error from IDrive: Left and Right Daytime running light/parking light.
what should i do? the installed was pertty easy, i dont think i can break anything. also i didnt touch the light with my hands.
thanks a lot.
E92 335i Fully Loaded | Procede Rev2 | ETS FMIC | AR Catless DP | AFE DCI | AA BOV | KW V2 | iForged Essen | VRS CF Trunk | M-Tech Sideskirts | M-Tech Rear | Ericsson Front GONE!
      06-25-2010, 12:10 AM   #2
mkiv
2JZ
63
Drives: 16 G500
and my car is 01/07 built. anyone have any ideas? do i need to add some resistors or anything?
      06-25-2010, 12:32 AM   #3
Mike@F1 Autohaüs
Mike@F1 Autohaüs's Avatar
195
Drives: ❤
07' models has a lot of problems with error codes. I suggest you go with a different LED angel eye setup that works w/out errors. Lux H8 or Angel iBright are both good options
      06-25-2010, 01:32 AM   #4
mkiv
2JZ
63
Drives: 16 G500
thanks mike! i had old Mtec V1 with no errors but they just went out, and they were not that white. hows the new V2 mtec? any errors with 07?
      06-25-2010, 02:10 AM   #5
Mike@F1 Autohaüs
195
Drives: ❤
I thought you had a coupe. You will have no issues with the MTEC E90 v2.1 on the 07' E90 sedans
      06-25-2010, 09:47 AM   #6
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
MTEC is error free at v2.1 now
      06-25-2010, 12:32 PM   #7
mkiv
2JZ
63
Drives: 16 G500
to mike: i do have an coupe, but on the back of the bulb(the old one replaced by RDs) is shows H8 Mtec, so i thought it was Mtec v1. no errors. but after checking ur website it was only for e90? thats weird. anyways i think i will buy a set of Apline HID then, i wish i can do the OSS but i just cant wait for the 1 week+ downtime, i have to use my car EVERYDAY. thanks for the help tho!
to E92-Lighting: im having problem with ur RD not mtec><
      06-25-2010, 02:11 PM   #8
Leroi
Leroi's Avatar
Drives: 2007 335i TiAg MT
2007 335i Coupe  [9.00]
I recently installed alpine HIDs and get the same errors on my early build '07(10/06) By turning off the daylight lights on idrive, the right sided error goes away.
Alex has been working on solution, as my car is one of 3 with this problem.
      06-25-2010, 02:55 PM   #9
mkiv
2JZ
63
Drives: 16 G500
wow thank you very much leroi! i was just about to order the Alpine kit! please let me know if alex fix the problem!
