do all 335i's idle like crap??
06-22-2010, 10:13 PM | #1 |
Rep 40
I don't get it! When my cars cold it idles nice n steady...once it's warmed up n oil temp is at 250 degrees it idles sooo much like crap! It bounces from 700rpm 600rpm 500rpm evens 400rpm! Also the car shakes a little n you can feel it in the steering wheel and seat...anyone have or had this issue before? It drives me nuts and at my last service visit they performed a scope? And said it's nomal! Thanks guys!
06-22-2010, 10:20 PM | #3 |
159
Rep 5,689
Seafoam your car, this helped a lot with mine
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
06-22-2010, 10:32 PM | #6 |
23
Rep 601
all N54s misfire slightly during a cold start. Just watch some youtube vids of a 335i/135i starting up, and you will hear little hiccups right at the start
--2009 BSM 135i-- -Manual, Sport Package, BMW Assist |
06-23-2010, 05:20 AM | #9 |
13
Rep 408
When you start your car cold the DME is keeping the throttle plate open 2-3% to keep the car from idling like crap or stalling. Once it is warm oil flows easier and motor has less resistance so it stops keeping the plate slightly open. If your HPFP is any more than 3,000 miles on it(thats when mine started) you start to get a shiver followed by a bog and then a little rev once the dme tries to compensate. Unfortunatly it will only get worse until the pump fails or bmw finds a real fix. Good luck getting BMW to do anything about this. I have tried and failed.
06-23-2010, 10:55 AM | #10 |
hi
129
Rep 1,140
My car has been doing it for months, dealer won't do anything about it since I have no codes.
2022 M Sport G05
Jb4, CTS catless dp, M performance exhaust, bms intake, IND goodies, Maxton kit |
06-23-2010, 11:21 AM | #12 |
133
Rep 4,764
This information helped with my rough idle with a warm engine. It runs completely smooth now: http://www.e90post.com/forums/showthread.php?t=386376
06-23-2010, 11:39 AM | #13 |
24
Rep 746
i have perfect idle... 650... yours is not normal...
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / JB Matte Black Grill / Tischer First Aid Kit w\Triangle / Tischer Hood Pad / "Custom" rear fog switch <---- SOLD!!!!
06-23-2010, 11:49 AM | #14 |
52
Rep 811
NO
Fix the problem before you add variables to the mix and further complicate things. If you've got a bad plug, injector, or fuel pump you might end up damaging it. Get it running smooth like it should, then mod.
'08 TiAg E90 335 M-Aero kit. - SOLD
06-23-2010, 04:43 PM | #16 |
13
Rep 408
If what you are describing is just a slight dip in rpm and then back up to 650-700 rpm and then be fine for a few minutes then repeat I would say its OK to tune. When my car does this I have to point it out to anyone in my car or they don't notice it. If it is obvious to others in your car you may have a bigger problem.
06-23-2010, 04:47 PM | #17 | |
94
Rep 1,184
two firs years no problem, steady idle. on beginning 2010 dealer replaced 6 injectors + 6 coils + 6 plugs because of misfiring at partial throttle... After that the idle is exactly as your car. the inspector from BMW belgium stated that this is normal for N54 lean burn engine. I state that it was fine when car was new! they could not explain, but insist it is normal: no action has to be taken |
06-23-2010, 04:49 PM | #18 |
230
Rep 3,899
Mine used to sound like a diesel when it was cold and make a ticking noise
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
06-23-2010, 05:33 PM | #19 | |
133
Rep 4,764
06-23-2010, 10:30 PM | #20 | |
198
Rep 3,840
///M |
06-23-2010, 10:40 PM | #21 | ||
"Booty Hole Bandit"
32
Rep 1,597
Car runs great at WOT, even with the JB3 on. It just idles like butthole!
2008 Montego Blue E92 335xi - MT - Sport - Cold Weather - Nav - iDrive - PDC - Logic7 - CA MODS: Unknown |
