06-22-2010, 04:22 PM | #1 |
Rep 165
OEM Rims and Maximum Brake caliper size?
What is the maximum aftermarket brake caliper size that I can run on the 2006 Z4M OEM rims (fit)? I have ordered a set of aftermarket track rims but would like the option to switch back-n-forth. It appears the 14" or 13" "big brake" packages in Brembo's or StopTech's will not fly according to Vivid racing.
The OEM brakes are well desgined and with better pads may be the solution most of you are running. I just want more pad surface and better heat distribution.
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
06-22-2010, 08:31 PM | #2 |
8
Rep 165
unless your tracking very often, i don't see the justification in spending so much money on BBK's. you'd be surprised how much braided lines, different brake fluid and pads will go. If that still fails you then and only then would i suggest something like a BBK. i've only run for 25-ish minute track stints in the mcouper and have not had issues with any major fade with the above changes.
note: you can fully open up the brake ducts on the MC for better cooling with a dremel. a lot of the local bmwcca MC owners recommended it. |
06-22-2010, 08:43 PM | #3 |
74
Rep 1,143
I always wondered why the duct was half blocked off with a riveted piece of plastic. I feel like that has gotta be a conscious design choice vs. a fully open duct...
06-22-2010, 08:57 PM | #4 |
187
Rep 2,138
Drives: Me
Don't need a dremel. Just pull the plastic flap off. The plastic rivets will just break off.
06-22-2010, 09:05 PM | #5 |
2426
Rep 11,667
^ only to clean up the tabs that remain.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
06-22-2010, 09:13 PM | #6 |
8
Rep 165
^ correct, sorry should have described it a little better
forgot to add, tires are everything. best braking system in the world isn't worth jack if your tires are horrible. lastly, you have to wonder if bmw made the half covered brake ducts so easily "fixed" for a reason... |
06-29-2010, 11:01 AM | #7 |
Rep 165
Anyone have A picture of one of these half covered brake lines and the plastic rivet?
I agree with the brake upgrade assessment. I will convert to steel braided lines, better fluid, and brake pads. Thanks!
06-29-2010, 12:18 PM | #8 | |
63
Rep 666
Drives: 2023 Hyundai IONIQ 6 SEL AWD
If you're not racing the car then SS brake lines are unnecessary bling. High temperature brake fluid like Ate Typ200 or Motul 660 and some competition brake pads like PF-01 along with R-compound tires like Toyo R888 or Nitto NT-01 is all you need for HPDS events. Of course I'm assuming you've got a lot of seat time and know how to get the most out of the car in stock trim.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
07-01-2010, 08:14 PM | #9 | |
Rep 164
I met a BMW mechanic last year that was working on the new 3-series. They were putting the same duct on that car. He told me that forcing a small amount of air in the proper direction into the wheel housing will keep air from coming in from outside the wheels causing turbulence at high speed. The duct has a aerodynamic function. It has very limited if any brake cooling effect because it blows almost completely over the tire. The flap was added during test to bring the correct amount of air over the wheels to produce the desired aerodynamic effect.
MR-S Track -2100lbs/300hp
Miata Z4M Coupe (Sold) |
