06-22-2010, 12:57 PM | #1 |
I found Jesus...He was Hiding behiind my Sofa
69
Rep 957
FS: OEM 20" # 214 Y-Spoke Sport Wheel w/Stag. Bridgestone Runflats *2009 E70 Takeoffs
The Following OEM Take Off wheels are For Sale Wheels were installed prior to delivery by Lauderdale BMW last MAY on my wife's 2009 E70 X5 SAV xDrive 30i. Total mileage on vehicle: 14K miles and are in very good condition. Should fit X6 models as well as other model years. Staggered Sport Fitment to make your BMW stand out and Handle Much better! SIZE: Fronts = 275/40/20, Rears = 315/35/20 TPMS sensors: (pre-installed) INCLUDED BMW Center Caps: (4) INCLUDED Bolt Pattern: 5 x 120mm Note: Tires will arrive as pictured below, mounted and balanced with center caps. Ready to mount on your ride. DETAILS: One front has tiny scuff and the other front has small rash on edge as well scuff marks. The rears look mint. Overall look of wheels and tires is VERY GOOD, near Excellent! See the pictures below for yourself. Front tire has more outer edge from bad car alignment, but still usable for several thousand miles before needed to replace. Car was Never involved in any accidents nor went off road. Scuff marks can be attributed to a suburban housewife trying to park as close to curb as possible but failing on at least two occasions. This set is priced very aggressively for a quick sale. Similar used sets (w/o the small curb rash and scuffs) are going for almost $3K. SOLD Fender Flares also available if you do not already have the wider rear OEM flares, add $150 for pair/ set. Will post picture soon of flares. Stock photo: Actual photos below (I have not touched-up wheels nor photos): rear front Front with scuff & rash SAME WHEEL AS ABOVE but with blemishes close-up (can be repaired easily when you replace tires)
06-25-2010, 01:18 PM | #2 |
69
Rep 957
Wheels are SOLD!
