XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      06-19-2010, 04:20 PM   #1
mario486
Mario
mario486's Avatar
Scotland
25
Drives: X1 XDrive 2.0d, Mini Cooper
BMW Mudflaps
Does anyone have any pics or experience with the OEM mudflaps for the X1? I am thinking of ordering a full set of 4 to protect my X1 from the winter grit.
      06-21-2010, 05:25 AM   #2
wyresoft
--X1--
United Kingdom
Drives: E84 X1 sDrive 2.0
We saw them on the test car at the dealers - proper moulded rubber sill protectors (not really 'flaps') - about £35 I believe and I'm considering getting a set as well.
318i E36, 320i E36 Touring, 530DSE E39, 525DSE E60,
325i Sport E46, 318Ci Convertible E46, Now in an X1 sDrive20d SE E84
      06-21-2010, 07:06 AM   #3
mario486
Mario
mario486's Avatar
Scotland
25
Thanks wyresoft. I have also decided to get them as both my other cars have wee chips from the winter grit. I plan to take my X1 up to the snowfields a lot this winter
      06-25-2010, 11:41 AM   #4
JR
United Kingdom
17
Drives: f45 218i SE active tourer auto
Just fitted a rear set [£35 each axle] they go on really well ,the test car we drove had a full set on ,didn't think they were very effective at the time but without them the rear door/bumper/window gets really dirty, will fit a front set soon,if you ask at the dealers they will print you out a set of fitting instructions
Bob
      06-25-2010, 04:35 PM   #5
pwceg
Drives: BMW X1
MUDFLAPS
Well i have all 4 mudflaps of the car and it changes the profile to a lower sitting car.it blends well with the black trim
      06-26-2010, 06:57 AM   #6
niknik
Portugal
9
Drives: X1 23d
Photo please!
      06-27-2010, 06:44 AM   #7
pereru
Spanish Member
pereru's Avatar
25
Drives: BMW X1
I read on another forum about a user that installed it on his E84 because he did not want to see how soiled the back of his car and says it does not work. The car has still soiling
Salu2
      06-27-2010, 11:58 AM   #8
pwceg
Drives: BMW X1
mudflaps
Have a look on my profile the cars there
      06-27-2010, 04:39 PM   #9
mario486
Mario
mario486's Avatar
Scotland
25
Thanks pwceg, mudflaps do look great (great car as well )
Definitely something to add to the accessories list for me.
      06-29-2010, 12:25 AM   #10
yohans
Drives: X1 xDrive20d
As an alternative to mudflaps does anyone have any experience of using clear protective film that can be applied to the paintwork?
I'm interested in protecting the front of the car as well as the mudflap areas.
      07-01-2010, 03:10 AM   #11
wyresoft
--X1--
United Kingdom
Had some clear plastic film bits on an Audi Quattro that I owned - needed on areas of the car that were vulnerable due to the design..... it was more like the front of the rear arches and areas like that.
      04-16-2013, 08:05 PM   #12
Driven2Drive
Drives: X1
Mud Flap Installation Instructions
I was unable to find the installation instructions so here are the instructions that the BMW parts department sent me. Hope it helps someone else. I wanted to add it to the DIY posting, but I just joined and am unable to create a new posting yet.
      04-16-2013, 08:58 PM   #13
peter123
Drives: 2014 X1 xDrive 28i Sport
Thanks Driven2Drive, very helpful; i'll plan to do this myself too. However, I must say that IKEA makes better instructions. I **think** that it means to partially remove the red tape (protective covering of double-sided sticky tape?) and then pull the rest off once the flap is positioned correctly. But I wonder if a bit of extra silicone caulking might help keep corrosive salt spray from collecting between the flap and fender? Input from anyone who has done the installation?
      04-17-2013, 08:03 PM   #14
miataken
Drives: 2012 X1, White, Xenon, Leather
Salu2
This is exactly the reason I wanted to get mud flaps but held off. The dirt collected on top of the rear bumper during winter time is at least 10x worse than rest of the car. I am not sure if it's from not having rear mud flaps or from using the rear wiper which pushing all the window dirt down. I hope someone can confirm on this matter if possible.
      04-19-2013, 08:30 AM   #15
Driven2Drive
Drives: X1
The red is the plastic covering on the double sided tape that helps hold the flap flush with the fender and lower bumper. I only did this on the driver rear side due to it possibly needing to be remover in order to remove one of the covers. Putting silicon would help with sealing the joint, but I am not sure it is necessary. Probably would not hurt unless there is a reaction between the silicon and the plastic or paint.
      04-24-2013, 10:15 AM   #16
lozw
Drives: X1 M Sport, 118 coupe Sport
FYI, it says the official BMW X1 mudflaps are not compatible with my M Sport.
      04-25-2013, 07:39 AM   #17
Teutonic
Teutonic's Avatar
2706
Drives: BMW
I have installed them as soon as possible. I am very happy with these mudflaps.
The back is not more soiled than without, this is a lie. Can still be soiled? What do you expect? Do they hang to the ground level? No. So?
Also, depends on your tires and theri profile, especialy in the winter.
Nonetheless, the front wheels are throwing water and dirt in the back too. That's what cars do when you drive in the rain. It is not only the rear tires. It is called aerodinamics. And it is a hatchback, it is a different design, it is more exposed, that's why you have a wiper with washer in the back. Some people buy their first hatchback and start talking non-sense due to their lack fo knowledge.
The person that says that with them it is the same like without them, lacks the technical common sense.
I have them and I can see how my 2012 X1 that manage two winters, looks in comparaison with a 2013 X1 without mud flaps. Mine has no rock chips on the silver paint, doors, nor in the black plastic that is around the wheel. The car loks like in the first day.
During the winter, I stop in front of the garage and with the brush I am pulling down all the snow that accumulates on them. I have seen the X1 without them and they have snow everywhere. True, even with them, you still get accumulated snow on the base of the vehicle but is no different than any other car. Plus, X1 has a different ground level, don't forget.
Also, they protect the bodyside of the vehicle, the wheel doesn't splash everywhere, including the mirrors.
What some people don't get is that they protect from snow, water, rocks, black asphalt spots from the hot road.
When you drive in the rain, have a look at the vehicle beside you and see the amount of water that wheels throw on the vehicle's body. Than think about the water, snow and the salt-water-snow combination that is thrown to your car. You will be convinced then.
Nobody seen how cars without mud flaps rusted on the front door?
If you live in an area that gets snow, salt and rocks on the road, then better install them if you love your car. They worth every penny.
PS
You don't need silicon. They are moulded around the vehicle and they look perfect.
      04-30-2013, 01:13 PM   #18
GreatStarSe7en
GreatStarSe7en's Avatar
Drives: 2013 X1 xDrive28i Sport Line
PS
really helpful review of the mud flaps, I just ordered after reading this.
One question though, does it require drilling holes in the fender or all you have to do is tighten the screws?
      04-30-2013, 07:11 PM   #19
Teutonic
Teutonic's Avatar
2706
Drives: BMW
Mine were installed by the dealer so I don't have the DIY guide. From what I have seen you don't need to drill any hole in the vehicle's body. You might need to make one litle hole in the plastic that covers the wheel well, however, I might be wrong...
      05-01-2013, 07:55 AM   #20
abwmma
Drives: BMW X1x
I did mine 2 months ago. You need to drill (2) 3 mm holes at the plastic trim one on each side of the vehicle. You also need a long punch to help to push in the plugs ( see picture 5). You may need extra room to that, but I have mine on a lift. It took 45 min. for the front and rear installation.
      05-01-2013, 09:41 AM   #21
CIWS
Moon Parasite
CIWS's Avatar
Drives: F98 X4M Competition
Had mine done last Friday. Not the best cell phone pic on a cloudy day, and a bit harder to see on black.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged
      05-01-2013, 10:37 AM   #22
GreatStarSe7en
match the body perfectly~~
Search this Thread:
Advanced Search
xbimmers
