Floor Mats - how to install?
12-13-2006, 03:44 AM | #1 |
63
Rep 1,417
Wee, got floor mats.
Now how the hell do you install them? When I got my car, they told me they run out and would tell me when they would be receiving some. They finally got some and sent me my way. I was OK with that since I figured floor mats wouldn't need rocket science to install, but they are trickier then I thought. Do I have to poke holes through the original carpet for the anchors? Where are these holes? I don't see them at all! The way I figured it was that holes were pre made for the mat anchors to screw right in. Am I thinking wrong? |
12-13-2006, 05:27 AM | #3 |
Torque junky
115
Rep 1,688
Drives: Remapped e90 330d
Yes, basically you have to 'ruin' the carpets by drilling a great hole through them with the screws supplied with the mats. I couldn't face doing this, however, and have left the mats unattached - they stay in place fine.
www.greenkeepers.fr - spécialiste des tondeuses à gazon hélicoïdales atco qualcast ransomes lawnflite
12-13-2006, 06:28 AM | #4 | |
1706
Rep 14,829
12-13-2006, 06:39 AM | #5 |
100
Rep 1,013
My e90 came with velcro backing discs already installed in the floor, so both my summer mats and winter mats simply velcro to those two discs. Must have been done at the factory or the dealership, but wherever it was done, there was no extra cost.
I'm sure the dealer would do it for free?
Paul
12-13-2006, 06:57 AM | #6 | |
550
Rep 6,563
under construction! |
12-13-2006, 08:12 AM | #8 |
76
Rep 2,104
wow, you have to DRILL through your floor mats to get them hooked????......................
SaaS - The world of tomorrow is already here...www.saaschronicles.com |
12-13-2006, 08:20 AM | #9 | |
379
Rep 4,320
Drives: '07 Z4 M Coupe
The summer carpet mats have a velcro disc that holds it to the floor. The winter rubber mats have a disc with a hook that holds the mat in place. This issue is that mats are not designed (at least on my drivers side) with disc placement being the same. On the passenger side, I used the same holes for both mats. On the driver's side I had to make two new holes for the winter mat. ***Again, this isn't drilling into the floorboard.*** It's basically applying enough force to screw the new disc through the carpet. If the plastic tip isn't sharp enough to pierce the carpet, just use a razor blade to poke a small hole.
12-13-2006, 04:58 PM | #11 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
I agree--not that hard. The instructions said to get a "sharp" object of some kind to poke a hole in the mat, but I found that applying a decent amount of pressure to the disc was enough to get through the carpet. No drilling required.
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
12-13-2006, 05:00 PM | #12 |
13
Rep 122
we got the rubber floor mats from bmw and they had the velcro on the back to attach to the floor it works very nicely.
2006 E90 325i, Titianium silver, 6MT, Black interior, Aluminum trim, ZSP, ZPP.
12-15-2006, 07:53 AM | #13 | |
4972
Rep 10,200
12-15-2006, 08:04 AM | #14 | |
379
Rep 4,320
12-15-2006, 05:32 PM | #16 | |
13
Rep 122
12-15-2006, 05:33 PM | #17 |
15
Rep 575
The front rubber mats each have two circles that you poke the screw-in hooks through (helps to pre-pierce this as it's about a mm thick). If you have the velcroed carpetted mats, the exchange of velcro retainers with the hook retainers takes about 2 mins. It is a good idea to restrain the rubber mats because they could drift on the carpet and get stuck under your foot while driving. They are heavy and tend to stay in place but why would the retainers be included if their grip was sufficient?
12-16-2006, 11:59 AM | #18 | |
4972
Rep 10,200
12-17-2006, 01:41 AM | #19 |
16 years and counting...
101
Rep 471
Okay, I have the carpeted mats and they've been driving me INSANE! I just thought they stay in their place, but my feet tend to move them all around, sometimes they'll go up and get caught in the clutch when it's depressed
Are these the types with the screws? I'm utterly confused.
E90 325i 6MT + E61 530xiT 6AT = N52B30*2
12-17-2006, 02:29 PM | #20 |
4972
Rep 10,200
Yes, the OEM carpeted mats have screws. My car is a MT as well, but I have not had many problems with them moving around or my foot getting caught when the clutch is depressed. Seems like this would only be a problem if the mats were not stationary--but I have even seen on other threads that some people don't even bother with the screws b/c the mats seems to stay in place well for them. I guess you could try removing the screws from their present location and trying a different spot? Maybe this would help.
