N54 --> N55, Any Interchangeable performance parts?
06-04-2010, 01:13 PM | #1 |
35
Rep 1,084
Is there any parts that can be carried over to the new engine? Obvious things like downpipes can't but how about the intercooler, intake, chargepipe, tune, etc....??
_________________________________________________
09 E90 LCI Msport, European Delivery |
06-04-2010, 01:19 PM | #2 | |
164
Rep 2,409
the engines are completely different, nothing can change over. Suspension and body wise you're free. Edit: OEM parts cant be interchanged but aftermarket intercooler will work but you will probably have to do some custom pipping for it to connect into the charge pipe. |
06-04-2010, 01:51 PM | #3 |
129
Rep 1,629
^+1, possibly.... eh, probably. No reason to change the tooling or location on the OEM intercooler from the N54 from BMW's standpoint.
Cars>Women
06-04-2010, 03:25 PM | #6 |
Joint Chiefs of Staff
4908
Rep 115,980
BMS has a new tune/hardware platform coming out for the N55 so their N54 tunes are not compatible. The intakes are also not compatible as the N55 has a whole new airbox, MAF, etc, to contend with. Early testing on a new intake resulted in poor results so the primary focus is on tuning now. And the car has responded very well to tuning. Not as well as an N54 but huge improvements over stock.
Mike |
07-08-2010, 02:44 AM | #9 | |
Rollin
Rep 66
07-08-2010, 01:41 PM | #10 |
aka Mike
106
Rep 1,395
07-08-2010, 01:54 PM | #11 |
IN THE KNOW!!!!!!!
12
Rep 431
It would be interesting if the exhaust manifold could be interchangeable-would make a single turbo swap a little easier.
Who knows, I'm sure someone ingenious enough to do it eventually.
2007 Jet Black 335i Coupe: Saddle Brown interior | ZSP | ZCP | ZPP | iPod integration. 1994 Hellrot 325is: Sport Package | PSS9 Coilover | AutoThority chip | AutoThority CF Intake | UUC pullies | Dinan HiFlo Throttle Body | UUC StrutBarbarian | UUC Evo II SSK | BMW Motorsports X Brace | Rogue Engineering DMS exhaust | Kumho Ecsta V700 R Comps | |
07-08-2010, 01:59 PM | #12 |
30
Rep 1,748
The IC looks like it could easily be replaced by an N54 FMIC, might take some doing, but looks pretty much the same... I'm going to have ------ attempt to hook up their FMIC onto my N55 X5 when it comes in, if it's a sucessful fit, everyone should be able to follow suit. No I will not name the Manufacturer of the FMIC, just be patient and wait for an update...
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
07-08-2010, 02:11 PM | #14 |
30
Rep 1,748
No go, from what I saw... It would have to be a Single Cone Filter, Most likely would need a dry (no oil) filter element... But As Mike (and Terry) have stated on this site and N54tech, their attempts at an intake system met with a loss of 30hp i believe...
I'm curious as to know how many cats we have on the N55 as well... And if the Cell count is known on them...
08-16-2010, 08:30 AM | #15 | |
146
Rep 1,403
08-17-2010, 01:26 PM | #17 |
Mad Linux Guru On The Loose
1121
Rep 5,396
Drives: 2008 335i Sedan, 2023 M3
Sometimes I wonder about people....
Is the SSK attached to the engine? No! It is attached to the transmission. So, if the N55 equipped cars have the same transmission as cars with N54 engine, then this will work. Let me guess. People will ask next if the CDV mod will work on N55.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
08-25-2010, 11:15 PM | #18 | |
Rep 53
Drives: '11 E92 335i
'11 335i Coupe | Black Sapphire, Saddle Brown, 6MT, ZMP...
