BMW M3 Forum (E90 E92)
EXXEL Distributions
      05-31-2010, 01:35 PM   #1
lux
66
Drives: 2023 G87 M2, 2011 E90 M3 Comp
Help with No Holes License Plate Bracket Install
Does anyone know if you can install the Autozone's "Bell / Adjustable license plate mounting bracket" without removing the bumper?
Here is the link to the original thread on the main forum by khaye1 back in April. You can see how he attached it to the grill in the bumper.
I used the search function and can't seem to find anything on how to remove the lower grill in the bumper? Is this possible or do I need to remove the whole bumper?
      06-17-2010, 06:46 PM   #2
cjb762
Germany
1222
Drives: 2013 135is, MG 6MT
Sorry I have no useful information right now, but I have been looking for something exactly like that. I will definitely let you know if I figure out how to do it though!
      06-17-2010, 06:59 PM   #3
cjb762
Germany
1222
oh - I don't know if you have seen this post:
http://www.e90post.com/forums/showthread.php?t=378549
but he was able to attach the same bracket to his car without using the bumper or grille. Of course, he did have to drill holes into the bottom of the bumper.
      10-22-2012, 11:46 AM   #4
rdollie
Drives: 2009 M3 DCT Sedan
So, did anybody figure out how to mount to the grill without removing the bumper? Can the grill be popped out without damage and reinserted?
      10-22-2012, 12:45 PM   #5
ducman
Drives: E92 M3
No. You can pop the bottom grill off but you can't take it out since it will be stuck behind the bumper. It may break if you bend/twist too much to try and get it out. The problem is because you're using washer/with bolt to secure the bracket. If you don't want to take the bumper off, you'll have to find another way of securing that bracket (maybe with wires, etc.) but the washer way is pretty optimal. GL
      10-22-2012, 02:25 PM   #6
rdollie
OK, thanks. I tried toggle bolts last night but they didn't quite work as they should have. I'm going to find a different size and not use nylon nuts and see if this route works as it would be easiest.
      10-24-2012, 09:42 PM   #7
XR_SIX
Bading-dong!
XR_SIX's Avatar
Drives: '11.5 E93 M3 AW, '09 R6
2011.5 E93 M3  [0.00]
I was able to install the mounting bracket without removing the front bumper. I used one screw and two zip ties to hold it in place. Looks great!
m3post
