ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      05-24-2010, 11:30 PM   #1
mhrir
23
Drives: Very fast
Z4M Track Brake Pad Install
What could it be?
New track pads from Porterfield!
Safety first...
Loosen the lugs...
Here is how I remove the retaining spring clip. Compress with clamp and then pull on it. It pops right out!
Compress the brake caliper piston. This makes caliper removal and installation easier. I use a socket as a spacer between the pad and clamp.
Removing the caliper bolt cover (upper shown)...
Loosen the upper and lower caliper bolts (upper pictured). Notice the green brake wear sensor wire. It just pulls out of the pad with your fingers. I try to grab it as close as I can to where it is clipped into the pad.
Pulling out the upper caliper bolt...
Pulling off the caliper...
Have something to rest the caliper on.
Pads removed. Looks a little corroded inside the piston!
The new rear pads!
They're only like this once... Notice the clip on the back of the pad that inserts in the the caliper piston.
Virgin... Not for long!
Reinstalling the caliper...
The new front pads...
Mighty!
That is a beefy pad...
The front pads install the same as the rears. The brake wear sensors are on the passenger rear and driver front pads only.
This may not be new info, but I had fun taking the pictures! Enjoy!
      05-25-2010, 07:57 AM   #2
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Great DIY! I'm sure this will help some people out there. I recall seeing someone asking about how to change pads. It really is a good starter DIY for people to get in touch with their car.
One thing I'd say is after you put everything back together, you might have to press the brake pedal a few times to extend the caliper before you get contact between pads and rotors.
      05-25-2010, 08:14 AM   #3
inTgr8r
inTgr8r's Avatar
2426
Drives: M2 Comp
Nice write up!
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      05-27-2010, 07:11 PM   #4
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
Originally Posted by inTgr8r View Post
Nice write up!
i agree, good pics too!
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      08-12-2010, 09:04 PM   #5
ngceru
Drives: 2003 Z4
I Not Only Would Like To Replace The Brake Pads But Also The Rotors. The Problem Is I Tried The Rear Rotors First And The It Is Stuck On There And Will Not Come Off. I Struck The Rotor (with A Rubber Mallet After I Applied A Generous Amound Of Wd4) All Around And Also The Hub With No Luck.
Is There A Tool For This Process Or Do I Need To Heat It With A Torch? Are The Front Rotors Just As Difficult? Is There A Different Procedure For Those?
Help????
      08-13-2010, 10:32 AM   #6
jmillet
jmillet's Avatar
63
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Originally Posted by ngceru View Post
I Not Only Would Like To Replace The Brake Pads But Also The Rotors. The Problem Is I Tried The Rear Rotors First And The It Is Stuck On There And Will Not Come Off. I Struck The Rotor (with A Rubber Mallet After I Applied A Generous Amount Of Wd4) All Around And Also The Hub With No Luck.
Help????
Did you have the emergency brake on? If so you'll never get the rear rotor off because the rear emergency brake is a drum type brake. Release the emergency brake and remove the two hold-down bolts and the rotor should come right off with a little persuasion.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      08-13-2010, 11:30 AM   #7
Quickid
11
Drives: 08 Z4MC, 06 X5 4.4i, 99 323i
I've never had luck with a rubber mallet. Assuming all is clear (parking break, etc), use a small sledgehammer (about 5lbs) for stuck rotors.
Make sure your car is standing securely on jack stands.
      03-08-2011, 10:39 AM   #8
SoonerMCoupe
Drives: WTB: E86 M coupe
Also, before you replace your rotors spray white lithium grease onto the hub and backside of the new rotor mounting holes. This should keep rust, dirt and other grime from creating an unbreakable seal. I did it on my 350Z, and never had another problem trying to remove rotors.
WTB: E86 M coupe. E-mail me e.goodwin@live.com
      03-08-2011, 07:16 PM   #9
RBull
12
Drives: 2007 M Coupe
Nice, I'll be using this one soon.
      10-09-2012, 07:04 PM   #10
melo
melo's Avatar
Drives: 07 M coupe
do you need to change the break wear sensors every time when you install new pads?
07 mcoupe ///M
      10-09-2012, 07:29 PM   #11
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
No.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      10-09-2012, 07:54 PM   #12
inTgr8r
inTgr8r's Avatar
2426
Drives: M2 Comp
Only if the pads are so low that it trips the sensor.
....otherwise no
      10-09-2012, 08:25 PM   #13
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
I tied off my brake pad sensors and didn't even re-connect them.
Causes more trouble than what it actually serves.
      10-11-2012, 03:26 AM   #14
melo
melo's Avatar
Drives: 07 M coupe
thanks for the info guys. my pads were worn out but the sensors didnt even fulfill its duty, nothing showed up in the panel lol
07 mcoupe ///M
      10-29-2012, 10:30 AM   #15
Alexander
Mad tyte EuR0 style boooi <--- Joke
Alexander's Avatar
Drives: E30, E85, MKVI
Nice write up OP.
      06-23-2014, 08:48 PM   #16
wasupdu
wasupdu's Avatar
Drives: Z4 3.0, CLS63 AMG
Resurrecting an old thread since I'm replacing my front and rear pads this weekend. I've replaced 'em on previous vehicles, but it's nice to see first hand pics. Great write up!
Normally I'd tie off the sensors too, but I plan to sell the car within the next couple years, so I'll keep everything proper for the next owner
On a side note - In terms of resale, how bad is it that I've done ALL of the maintenance on the vehicle myself and the car hasn't been to the dealership in 7+ years? I may have a receipt for oil here and there, otherwise no documents. I figure it's only worth $15k at this point, so I might as well hang onto her
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG
      08-05-2014, 02:46 PM   #17
IVI
I did this to myself.
IVI's Avatar
Drives: 2006 Silver Z4 M Roadster
Proof is in the pudding. Personally, I've spent a fair bit of money at the dealership on simple things. Once I realized how much, I started to do more maintenance myself, so I can appreciate the choice of DIYing all the work. Plus, occasionally dealerships do a shoddy job or take shortcuts because of time and cost constraints - I've been a victim of this several times, and getting them to fix their mistakes is an inconvenience. If you keep everything in working order and your car drives like it's been well-maintained, then you shouldn't have a problem when you go to sell it.
      09-16-2014, 10:57 PM   #18
sipman
Drives: 2007 Z4MC
nice write up. the raybestos bite and lack of fade is amazing! even compared to full pfc 01 . I wish they did rears for us at a good price.
don't forget your high temp silicone lubricant for the slide pins, or some go for the ceramic extreme high temp lube. just don't use anti-seize.
      09-16-2014, 11:31 PM   #19
Aries326
Aries326's Avatar
Drives: 2008 Z4 3.0si, 2013 E92 M3 ZCP
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
I just got my jack and jack stands. I heard the brakes start to grind the other day. Definitely going to try changing my brakes this winter. Maybe I'll do the stop tech upgrade kit with the steel cable lines, new pads and slotted rotors.
zpost
