Manual Transmission Question
12-07-2006, 12:27 AM | #1 |
238
Rep 2,366
Drives: 1 M Coupe
1.)Anybody here have a problem with 3rd gear being a bit tight sometimes.
2.) Anybody experience a burning type smell for the first couple hundred miles on there cars from trany or anything on those lines? 3.) When you upshift in other words from lets say 2nd to 3rd do you give the car a little gas to make the shift clean or do you remove your foot compleltly off the gas until you have completed the shift. |
12-07-2006, 12:35 AM | #2 |
Member
310
Rep 22,825
1) No
2) Yes 3) upshift or downshift? a. upshift from 2 to 3, shift first, then gas as clutch pedal is released b. downshift from 3 to 2, rev-match (give gas), then engage clutch (RPM will depend on speed of car) |
12-07-2006, 12:37 AM | #3 |
238
Rep 2,366
Drives: 1 M Coupe
im assuming you learned how to rev match teh car by watchin how high it revs in certain gears or do you assume.
12-07-2006, 12:54 AM | #4 | |
Member
310
Rep 22,825
12-07-2006, 02:46 AM | #5 |
20
Rep 345
1. no
2. yes 3. depends on the rpm im shifting and how fast im shifting. if im doing a higher rev quick shift, no gas cuz theres no need to rev match. but if its a low rpm shift like 2-3 then i might do a touch of gas to make it smooth. |
12-07-2006, 03:57 AM | #6 | |
Rep 111
12-07-2006, 06:31 AM | #7 |
1677
Rep 6,599
1) No. SOmetimes it feels tight (notchy) going from 1st to 2nd. Overall, not the best MT I've seen...
2) Yes 3) Most of the time -- No. However, the MT seems to have the RPMs falling prett fast, so it could be "jumpy" if not careful. |
12-07-2006, 07:00 AM | #8 | |
552
Rep 6,563
I wonder how these step are different if you remover the CDV?
under construction! |
12-07-2006, 07:17 AM | #9 |
28
Rep 126
It's hard to describe but if I shift from 2nd to 3rd quickly it seems that its not as direct as say when I go from 3rd to 4th or 4th to 5th quickly.
12-07-2006, 07:35 AM | #10 | |
552
Rep 6,563
12-07-2006, 08:38 AM | #12 |
Rep 233
I rev-match. Shifting is pretty smooth.
Incidentally, I was having a negative experience between gates (notchy, crunchy) but the other night on a desolate section of the highway after work (I'm an investment banker - some late nights this one at 4 am) where there are no exits (or cops, ever) I took it up to redline in 2nd, 3rd, and up there in 4th (got to 125). After that, car shifts as smooth as butter. Weird, not sure why that would matter. But, it did. Try letting the car off its leash some time if you can and see if it helps. |
12-07-2006, 10:33 AM | #13 | |
552
Rep 6,563
12-07-2006, 11:11 PM | #14 | ||
Member
310
Rep 22,825
Downshift to decelerate: CDV no big deal (to me) |
