Wind Noise from Sunroof
12-03-2006, 08:36 AM | #1 |
26
Rep 241
Noticed today that I was getting a fair amount of wind noise around the front seal of the sunroof, especially when the sun shade is open. Does anyone else notice this?
I have had a few cars in the past that the alignment has been off, or maybe this is normal. Thanks Jb |
12-03-2006, 09:43 AM | #2 |
571
Rep 7,519
Drives: 2009 E90 335i MT
I presume from how you wrote your message that the sunroof is closed and not open. Are you sure it is completely closed? If it happens when the sunroof is open then it is probably normal. The plastic sawtooth flapper is supposed to reduce this.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
12-03-2006, 09:48 AM | #3 |
274
Rep 6,510
My x3 had a seal that would come up in the wind... check the rubber seal to make sure it doesnt come up at all around the glass, it should be totally flat with the cars roofline.
12-03-2006, 10:01 AM | #4 |
Rep 229
the seal may be damaged or messed up or something, check
Ordered: 2007 328i Sedan/ Montego Blue/ Beige interior with wood trim/ STEPTRONIC/ Sport package/ Premium Package/ Cold Weather Package/ Comfort Access
Comes in January |
12-03-2006, 12:22 PM | #5 |
Got Seoul?
116
Rep 2,862
Drives: 2012 535i MSport
Check to see if the sunroof is closed properly first then take a look at the seal and see if there are any cracks or holes that would make the noise. You shouldn't hear any noise with it closed.
Can you say Alooooha?
[SIGPIC][/SIGPIC] |
12-03-2006, 09:22 PM | #6 | |
811
Rep 7,750
12-03-2006, 09:50 PM | #7 | |
12
Rep 715
Do a test on the highway.. Open the sunroof alittle so that the sawtooth wind breaker doesn't come up yet, then open it all the way. You will notice the different. Also, if I'm not mistaken, the flapper (as you call it) is only spring loaded and you should be able to pull it down with your hand when the roof is open (I could be wrong, and it might just get locked in the up position when the roof is fully open). Try the same test then...
E46 325xi Oxford Green/Sand Leatherette/Myrtle Wood Auto ZCW - Retired
E90 330xi Mystic Blue/Black Leather/Aluminum 6sp Manual ZSP/ZPP/ZCW/CA - Retired F22 M235i Mineral Gray/Red Leather/Aluminum 6sp Manual ZPP/ZTP |
12-03-2006, 10:28 PM | #8 |
76
Rep 2,104
Buy Acura to get quiet sunroof...
SaaS - The world of tomorrow is already here...www.saaschronicles.com |
12-03-2006, 11:38 PM | #9 | |
Got Seoul?
116
Rep 2,862
[SIGPIC][/SIGPIC] |
12-04-2006, 03:03 AM | #10 |
87
Rep 805
Drives: R NineT, X1
Me too!
Recently I have noticed the same thing, noise close to the front of it with the shade open. I'm sure I would have noticed before if it was this loud. Maybe the seal has deteriorated. I'm going to take mine in soon to deal with this problem and the flat spot/hesitation around 3800 rpm's. I don't have a sawtooth flapper, mine has a thingy with a net on it..........goes up about 3 inches above the car, and yes it causes more sound, and with out my rear windows cracked my sunroof causes crazy wind-bass in my car, but that has been covered here many times........
GET LOST!
www.lostrider.com |
12-04-2006, 06:32 AM | #11 |
129
Rep 579
Get your car checked out att the dealer. I almost always have my sunshade open but I've never heard any excess noise from that area.
Instagram: te37sl_m3
12-04-2006, 11:42 AM | #12 | |
571
Rep 7,519
12-04-2006, 01:01 PM | #13 | |
Rep 105
Don´t know what made me get this stupid sunroof again in the E92 since I never use it anyway. It is quiet at normal speeds (up to around 200/220km/h) although at speeds beyond, it does generate some heavy noise. At vmax (250km/h) it sounds as if the sunroof is about to disintegrate, even with the shade closed. Also the side windows do get a "little" noisy as well. As long as the wheels don´t come off I couldn´t care less |
