Boost gauge placement
12-02-2006, 03:25 PM | #1 |
50
Rep 287
Hi guys,
I'm new to the BMW family with my E90 335i. I'd like to intall a boost gauge. Haven't decided on what model i will get but was wondering if any guys have installed one yet? And where to put it to keep a clean looking interior? Also where did you tap off from? I was think of tapping of the diverter valves lines, but maybe there is a line inside that I can tap off. |
12-02-2006, 04:33 PM | #3 |
Outlaw
90
Rep 250
Drives: 2015 M4 JB4
does anyone make a digital gauge??? kindave like the one built into the profac b spec II boost controller...
Mina |
12-02-2006, 05:37 PM | #4 | |
Rep 148
http://www.amazon.com/exec/obidos/AS...o-20/ref=nosim
2007 335I, " Gray", Black Leather, Step, Comfort, ZCW, ZPP, ED - Oct 5, Dropoff Oct 9, redelivery Nov 15.
12-02-2006, 06:00 PM | #5 |
10
Rep 136
www.egauges.com sells gauge pillar pods.....
12-03-2006, 12:01 AM | #6 |
The 3 Day Diet!
19
Rep 630
Drives: Space Gray e92, 88 911 Cab
I miss the boost gauge i had on my 89 944 turbo S. I really want to get one on my 335i. Its awesome seeing the boost as you accelerate.
12-03-2006, 06:30 PM | #8 | |
213
Rep 3,835
Drives: Jerez E90 M3
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 | |
12-03-2006, 07:11 PM | #9 | |
335
Rep 7,719
12-03-2006, 07:13 PM | #10 |
50
Rep 287
Its not about rice and bling bling.
Its about having the information about the car. The 335 should have not only come with a boost gauge, but also a water temp gauge. I am so used to looking at the water temps gauge as a reference to when the car is hot enough to ge on it.But also an indication if the car is maybe getting to hot before overheating happens. Maybe its just me but i dont like using just warning lights. The factory cluster is nice and simple, but having boost and water temp would have been nicer. Even digital on the computer would have been nice. |
12-03-2006, 09:05 PM | #11 |
Model
23
Rep 283
Drives: Fast and Loud
Garage List 1999 M3 [0.00]
2001 ML55 AMG Desig ... [0.00] 2001 BMW X5 4.4 (SOLD) [0.00] 2003 VW Jetta 1.8T ... [0.00] 2007 335i (SOLD) [0.00] 1966 Pontiac GTO [0.00] |
In the 06 GTI there is an EGG to get the Information Display screen on the AC's temperature screen. Pretty nifty... My friend showed it too me. There is a sequence of settings you set the AC to so that you can access this "Diagnostic Mode". My same friend with a 540i had a way of accessing the Diagnostic Mode on his Critical Info screen on the cluster. He got it to read out real-speed, real-rpm, some battery thing, and maybe even oil temp. I'm pretty sure the car's ECU monitors all these things with sensors so someone should be able to read these. I dunno, just my .02$
I think something should enable the boost to readout on the factory clusters critical information screen (I'm just going out on a limb guessing that 335 has one...)
“No man has the right to be an amateur in the matter of physical training. It is a shame for a man to grow old without seeing the beauty and strength of which his body is capable.” ~ Socrates
12-03-2006, 09:43 PM | #12 | |
50
Rep 1,600
Drives: e90 335i
12-03-2006, 11:29 PM | #13 |
50
Rep 287
I agree the oil temps is important too. Speacially on the track.
But since the oil temps take a long time to go up, speacially in winter. When the water temp reaches operation temp it's the go light for me. Giving me the heads up that i can start taking the revs a bit higher. OK but back to the boost gauge. Nobody installed one yet? |
12-04-2006, 12:29 AM | #14 | |
Rep 73
1993 325i
12-04-2006, 05:13 AM | #15 |
84
Rep 1,575
Everything made wisely by the Germans.
No boost gauge needed
Procede V4 , Catless DPs, Forge FMIC, Injen Intake, VK Oilcooler, Hartge Quads Exhaust, Modded CDV, Synapse BOV Kit, BMW Performance 335i SSK Kit, P3 vent boost gauge Space Grey 335i -> See more pics HERE |
12-04-2006, 10:50 AM | #16 |
10
Rep 122
SO how do you know if you have a boost leak if you have no information about what you are boosting? How do you know if your boost selinoid or waist gate are not stuck open? With out the gauge, you do not know. Anyone that is looking to add more power needs one.
2016 SO M4
12-04-2006, 11:35 AM | #17 | |
335
Rep 7,719
The easiest way to determine a boost leak is to look at a boost gauge to see if there is any abnormal drop, and if there is...time to run a boost leak test and find the culprit(s). All the people who said that German engineering makes it OK not to have a boost gauge are wrong, it doesn't matter how well the car is made...a turbo'd car has a lot of pressure running through the wastegate, turbo tubes, bov, intercooler pipings, etc. and if there is a loose connection that allows air to prematurely get out, performance will suffer. |
12-04-2006, 12:11 PM | #18 | ||
84
Rep 1,575
12-04-2006, 03:30 PM | #19 |
10
Rep 122
I have owned many turbo cars, 98 Supra TT, WRX, STi, and all of them got an aftermarket boost gauge, and EGT sensor in the downpipe. With the Supra, on stock twins I used to run 19 PSI all the time, and pop IC pipes off. The gauge was a real help. As a matter of fact, I loved teh supra I6 so much, it was half the reason I bought this 335.
2016 SO M4
12-04-2006, 04:42 PM | #20 |
84
Rep 1,575
Question : How can you fit a boost gauge inside the fine 335 interior without ruining it?
(at the end of the day, you must maintain the style) If you find one that looks good inside the 335 let me know.
12-04-2006, 05:17 PM | #21 |
The 3 Day Diet!
19
Rep 630
I ran 1.4 bar on my 944 turbo S with the Autothority chip andd banjo bolt (relief vlv). Stock the car was .7 bar or 8.5 psi. you need the gaauge to tell you if the upgrade your getting is what was promised. Shiv is stating only 10-11 psi on the stage 0 - wish it was more. You will be able to verify the boost and when it is applied. I wish we could then provide feedback to Shiv to make map changes for our personal tastes.
01-05-2007, 10:23 PM | #22 |
196
Rep 4,095
Drives: F30 328i
any updates on this!!
