TPS on 2007 E90/92 328i????
12-01-2006, 03:34 PM | #1 |
17
Rep 279
I have been searching all day and can't seem to find a answer. I have even called two different dealers and they haven't got a clue about the 06's not to mention the 07's....
With that in mind, does the 2007 US Spec E90/92 328i have the TPS sensors on each wheel or is it only on the 335i E90/92? I am getting ready to install winter tires/wheels on my wifes car tomorrow and want to make sure I don't need additional sensors for the new wheels? If so, are they on the valve stem or rubber banded to the inside of the wheel? (Part # or link would be great) Sorry if the post is a repeat but I couldn't find it in my search and the posts that were related DID NOT have an answer to the question. Thanks, Josh
2007 E90-328i (Sparkling Graphite w/Black Leather & Alum)
ZPP // ZSP // ZCW // 205 // 322 // 417 // 507 // 522 // 4AD |
12-01-2006, 03:56 PM | #2 |
27
Rep 959
I've read:
E90 uses passive sensors for both 2006 and 2007, all versions E92 uses passive sensors on the 328/328xi E92 uses active TPS for the 335
330xi SG/Terra/Burl -- ZPP, ZSP, ZCW, CA, Sirius, PDC |
12-01-2006, 04:41 PM | #3 |
17
Rep 279
Thanks and I don't mean to question you but where did you find this info?
I really appreciate your help, I just want to make sure this is "official" and a usefull thread that everyone can benefit from. I guess I'll find out for sure tomorrow but I was looking for something official before I tested it on my own in the morning.
12-01-2006, 10:30 PM | #5 |
JetInsp
12
Rep 289
I went through the same situation.
THE ANSWER IS : If your oem wheels have a rubber (flexible) valve stem you dont have the sensor in the wheels. If this is your application remember to reset the the tps after changing the wheels. |
12-02-2006, 06:38 AM | #6 | |
550
Rep 6,563
under construction! |
12-02-2006, 08:23 AM | #7 | |
17
Rep 279
I'm off to look and get the tires/wheels swapped...
12-02-2006, 12:38 PM | #8 |
17
Rep 279
I just wanted to post an update. I mounted another set of wheels and tires today that were 16" and have had no problems with the computer or TPS warning in the car. I had the rubber valve stems on the stock 17" Sport wheels so everything appears to be fine at this point with the new set.
With that in mind, I assume that the 2007 328i E90 DOES NOT have the TPS on the wheels....
12-02-2006, 01:25 PM | #9 |
JetInsp
12
Rep 289
It achieves the same result using an indirect method i.e using the ABS sensors as a source for the data needed to compute TPM. The rest of world is using this method also. Because of the F.rd tire blow out fiasco all autos sold in the USA must be equipped with direct tire pressure monitoring devices.They must be 100% compliant by Sept 2008.
12-02-2006, 03:37 PM | #10 |
17
Rep 279
Gary,
Thank you for the info/help..... :rocks:
12-04-2006, 10:50 AM | #11 |
Moderator
369
Rep 4,745
So far the only vehicles that have come through with live pressure sensors have been the E92 Coupes.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
12-04-2006, 08:43 PM | #13 | |
550
Rep 6,563
