Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > High octane fuel
      11-26-2006, 05:05 PM   #1
SROC3
The limit of adhesion is my home.
SROC3's Avatar
Drives: Like a Boss.
High octane fuel
The recommended Octane for our cars (US side) is 91 octane (or 93). There is a gas station near my house that sells 102 octane gas. Is it a bad idea to put it in or will the ECU automatically adjust to this fuel type? The last thing I want is the engine running too lean and detonating.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
      11-26-2006, 05:07 PM   #2
Mr. Smith
Drives: 2007 328i Sedan (Ordered)
i am not sure about you question but i have my own:
Do you have to use 91 octane or higher, can you use Mid-Grade gas? or even Low-Grade?
Ordered: 2007 328i Sedan/ Montego Blue/ Beige interior with wood trim/ STEPTRONIC/ Sport package/ Premium Package/ Cold Weather Package/ Comfort Access
Comes in January
      11-26-2006, 05:13 PM   #3
bobnaz
BMWCCA/NASA
bobnaz's Avatar
24
Drives: E92 Coupe ZP/ZS/Dinan ECU+Exh
1999 M3  [0.00]
2007 ZSP ZPP Step a ...  [0.00]
91 or better. I think you can even use 89 according to the manual. You could spend more$$, but I don't think you will notice any difference. IMHO.
07 335 Coupe ZP ZS DinanECU+Exhaust
06 330I (retired)
97 M3 (retired)Dinan Stage 1
01 XK8 Conv 98 Navigator
99 M3 (race car)IP,PS1,and CR-3
      11-26-2006, 05:16 PM   #4
///Matt
United States Marine
///Matt's Avatar
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
if you use anything below 91 your DME (digital motor electronics) will retard your timing to avoid knock, and you will lose a LOT of HP. VERY noticable loss.
102 will make your car run better, faster, and get better mileage, except you'll have your foot in it all the time, so your mileage will go DOWN. lol.
The problem with 102 is that it will wear out your Catalytic Converters more quickly. How much more quickly? can't say. but it will.
      11-26-2006, 05:29 PM   #5
///Matt
///Matt's Avatar
2006 330i  [0.00]
Forgot to mention... you probably won't notice ANYTHING on your first tank of 102, unless you reset all the fuel trim adaptations at the dealer. Otherwise, it will take a couple tanks for the car to figure out it's a badass. =)_
      11-26-2006, 05:35 PM   #6
wj4
Drives: E90 manual 335i
on stock ECU, that high of an octane wouldn't do much good for the car.
A lot of my friends use c16 or 100+ octane gas when racing to go with race maps on their ECU. This helps shorten the 1/4 mile time down a bit, but since you are stock, it won't do much good.
And let me take a guess, is this gas station happen to be a 76 by anychance? lol.
      11-26-2006, 05:42 PM   #7
Mr. Smith
so mid-grade is okay, and low-grade is a definent no-no
Comes in January
      11-26-2006, 05:43 PM   #8
///Matt
///Matt's Avatar
2006 330i  [0.00]
anything under 91 is a no no. don't do that to your BMW bud. it's not a toyota.
Also... wj4....
You're wrong. I'm sorry to say, but you're wrong. I've tried high octane gas. It's a real benefit. i mean REAL. like about 20 hp real. I'm not kidding, or making it up. Again, I'm talking about putting high octane in and then resetting the DME adaptations, not just putting it in and driving.
      11-26-2006, 06:01 PM   #9
mistersamu
mistersamu's Avatar
Spain
Drives: Bmw 525d F11
in spain octane is 98 jejej no problem
      11-26-2006, 06:03 PM   #10
jxsanche
Drives: Ducati 900SS
I find this link rather interesting:
http://www.cars.com/carsapp/national...odaysgas1.tmpl
      11-26-2006, 06:06 PM   #11
wj4
Also... wj4....
I've put 100 octane in my car when it was stock and dyno'd it. It was a little bit more than 91 octane. There's a little gain, but my butt can not feel much of a different when I drove it. The last time I dyno'd my car, I dyno'd at 300whp on 91 octane, and I put in some 100 octane just for the hell of it, and it yields about 330whp. I too would like to think that the 100 made my car faster as it is pricey per gallon.
100 octane isn't worth it if your car isn't prepped for it IMO. Just look at Shiv's post about his tuning in Canada where they have 94 octane, and compared his dyno result to his own car with Cali's inferior 91 octane.
There's a reason why they sell high octane gas at LACR and other race tracks
      11-26-2006, 06:11 PM   #12
13307
30
Drives: 18 F82 M4 ZCP Black/Black
I wish that were the case
Unfortunately in this car, you will not gain any measurable HP with the higher octane. Believe me I wish this were true, but 20 years of racing everything from shifter karts, motocross, superbikes, to scca formula ford events has shown that the stock ECU's will not compensate for higher octane, the sensors(used to be knock, now are straight up timing) are unilateral, the ECU does not have the programming to detect higher octane and therefore compensate, bear in mind that the ECU does not have the parameters to advance the timing beyond factory only retard. Now that being said, if you look at any race vehicle(2 or 4 stroke), no one uses factory ignitions(for older low tech engines) or ECU's. I just recently went through this on a 5 valve yamaha engine in which I increased compression throughout the range, ported and polished the heads, and reprogrammed the ECU, all of this then requires me to run VP110 fuel, if gains could have been made with simply running higher octane without modifications, every R1 out there would do it. Again, once you start tweaking the engine, you benefit from the higher octane(although more accurately you require it), but I defy anyone to show increased wheel horsepower with simply increases the octane and nothing else. Of course you could have Shiv chime in and talk about how he tuned the 335's and see what he did with required fuel, but I am betting he'll say the same thing, he'll give you the best performance based on what fuel you say you're willing to run, not the other way around. If you speak with Dinan as well, they used to do custom programming for the old M3's for GT events and you would tell them what the spec fuel was for the class or specific event and they would tune the car for that. Now, one concession I will make is with regard to the recent ongoing reports of fuel coming in sub-spec on octane levels at the pump, and if you are buying 91 and only getting 89/89.5, and then you run a race gas, you will feel the horsepower, not because the extra 8 points of octane are benefitting you, but because you were not getting the minimum required to begin with. I'm in SE PA, and I stock GT100 gas for one motorcycle and one shifter kart, as well as VP110 for a moto, if anyone is interested in trying it on the dyno. I said if anyone is interested, because without witnesses, the forum will light up with people disputing the results! Best of Luck.
      11-26-2006, 06:17 PM   #13
Jaws
Jaws's Avatar
45
Drives: 2006 325i mt
Different scales. Europe use RON, NA uses AKI.
2006 325i - Sparkling Graphite
2000 S2000 - New Formula Red
2007 Chev Silverado crew cab Z71
      11-26-2006, 06:23 PM   #14
Jaws
Jaws's Avatar
45
Bang on. To summarize: Using higher octane than what the vehicle was designed for is a waste of money. You can only get more power with advanced timing and the PME has no way to advance the timing only to retard the timing through knock sensor inputs.
      11-26-2006, 06:32 PM   #15
martieg
Texas
Drives: 330i Black Sph PP/SP/NV/MTk
2006 330i  [0.00]
From HowStuffWorks.com - http://auto.howstuffworks.com/question90.htm
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
According to this, the only way to get a benefit is to increase compression ratio. Maybe that's what Matt is referring to. Without any mods or adjustments, you won't get anything from the more expensive gas.
Other cool links -
How turbochargers work - http://auto.howstuffworks.com/turbo.htm
How to increase the HP of your car - http://auto.howstuffworks.com/question395.htm
      11-27-2006, 12:53 AM   #16
SROC3
SROC3's Avatar
Glacias......glacias everyone.....mucho greato informacion!!!!!! Thanks so much!
      11-27-2006, 02:57 AM   #17
Convertible
Finland
15
Drives: BMW
Here in Europe BMW manuals say that BMW engines are made for 98 octane fuel (ron) if you use 95E usually the lowest oct. we got, then you'll experience power loss and higher fuel consumption.
There was a test in a Swedish magazine(Teknikes Värld) between BMW 130 (claimed 265hp) and a Audi A3 Sportback 3.2 quattro (claimed 250hp). They also tetsted the cars with different fuels. The Audi was brought to the test with 95E in the tank while BMW had 99E in the tank.
Well the Audi gave 219hp with 95E with 98E 248hp.
BMW 265hp with 98E and 272hp with 99E.
Here,s some result's from the test.
Audi BMW
0-50 km/h 2,55 2,53
0-100km/h 6,54 6,40
0-200km/h 29,14 22,46
402m 14,76 14,39
402m 154,80 163,68 km/h
      11-27-2006, 05:42 AM   #18
SoYank
SoYank's Avatar
Drives: 2009 E90 335i MT
So if Iso-octane has a 100 octane rating and heptane has 0 octane and gasoline is a mixture of both, how do you get an octane rating above 100?
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7
European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor
Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269
      11-27-2006, 07:09 AM   #19
bobnaz
BMWCCA/NASA
bobnaz's Avatar
24
1999 M3  [0.00]
The higher octane sold at tracks are for modified engines that need the higher octane for a slower burn, still think it's a waste of $$ for street cars IMHO. Most guys I race with that have E36 M3's with a few high end mods mix75-90% 91 and 10-25% 101. I believe that Canadian and US autos are programed differentely
06 330I (retired)
      11-27-2006, 10:11 AM   #20
RGB
RGB's Avatar
8
Drives: 325i Auto.Active Steering
In Spain I'm using 95 octane -BMW reccomends here 95 to 98- and the car runs
ok. I'm going to do a few 98 fill ups and see if I can feel any difference.
[IMG][/IMG]
      11-27-2006, 08:48 PM   #21
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
Also... wj4....
Aha! Lol. I figured
      11-28-2006, 09:15 AM   #22
carl_d
carl_d's Avatar
United Kingdom
41
Drives: E90 335i M-Sport N55 6SP Nov10
+1 Totally agree ... spot on.
Also... wj4....
2010 E90 335i M-Sport, 2005 E90 325i M-Sport, 2003 E60 520i, 2002 E46 330i Sport II, 2000 E46 325i Sport I, 1999 E46 318i, 1998 E46 323i SE, 1996 E36 323i SE, 1996 E34 518i, 1995 E36 320iA, 1994 E36 316i
