Oil splatter on front grille area.
04-09-2010, 03:38 PM | #1 |
74
Rep 2,848
I noticed last night that there was a little bit of engine oil on the front lower section of the kidney, got home cleaned it all off...today went out there again about 15 min ago and there is oil again in the same spot, and cant seem to figure out where its coming from. any ideas? all thats on top is the intake and the raid. the oil was just changed yesterday and im driving the car for a cpl of days to see if its worth buying. im not familiar with this engine and didnt know if there was an over flow for oil, any help would be great since im suppose to pull the trigger tomorrow.
04-09-2010, 03:49 PM | #2 |
7
Rep 143
Drives: 335i Coupe 6MT SpaceGrau
What model is it?
Current: 2007 335i coupe SpaceGrau
Retired: 2006 325i, 1994 325i |
04-09-2010, 03:56 PM | #3 | |
AC Schnitzel
85
Rep 546
04-09-2010, 04:24 PM | #4 |
74
Rep 2,848
its a 2006 325i, checked all the caps...top and sides of engine are oil free, i noticed there was a trail of what seemed to be an oil'ey substance starting behind the drivers xenon housing running along the top of the raidiator. and below the intake opening, then down to the grilles, there was a hex nut behind the light assembly with what seemed to be a bit of oil resedue in there...were 06 325s equiped with oil or trans coolers? im not sure what is behind that housing...and the car is a CPO till 2/2012 so im not sure if this is covered or not
04-09-2010, 05:30 PM | #6 |
74
Rep 2,848
i wish i thought it was something simple like that, for some reason tho there is a trail of oil residue going from the grille up towards the intake inlet, then heads towards the right to behind the drivers headlight housing, there is something there, and what appears to be some oilish build up. its inbetween the air box and the headlight assemb. and if u look at the catch pan below that certain area there is oilish residue there as well...so im stumped cause i cant find any sources to show were specific engine components are for this car
04-09-2010, 06:33 PM | #8 |
7
Rep 143
If it is for sure oil then I have not a clue where it could be coming from. The only thing I know of that has any sort of pressure valve that will run out is on the radiator, and that should be closed unless someone fooled with it and forgot to screw in back in.
04-09-2010, 06:44 PM | #9 | |
74
Rep 2,848
04-10-2010, 10:09 PM | #10 | |
169
Rep 660
04-12-2010, 02:37 PM | #11 |
74
Rep 2,848
long story short i took it in to bmw to have a PPI inspection done and said to the SA "hey btw there is this issue", they had it for 2 hrs, came back and said that someone had just spilled oil during the oil service 3 days prior and that some had collected under the intake housing above the grilles, hints why it was dripping down...they took the intake apart, and the catch pan, ran the car to make sure there were no leaks, pressure cleaned everything to new, and put it all back together...problem hasnt been back sense. now all i have to address are new tires and replace the dry rotted weather stripping.
