Ridiculously annoying squeaking/chirping behind dash in warmer temps?!?!
03-22-2010, 08:06 PM | #1 |
18
Rep 71
Everytime the temperature gets warmer (>70) in my car, there is a really annoying constant squeak or chirp eveytime I go over uneven road surfaces. The noise goes away when the temperature cools down. Anybody know where this is coming from? I've pulled apart my left vent, light switch, and instrument cluster, but still can't find it.
It ONLY happens when it gets hot in the car, e.g., when I go out to lunch after being parked at work. It sounds like a mouse or little bird being tortured behind my dash...every single rut or any eneven surface will start the chirping. It's not tied to the steering wheel, and I recently had the steering column replaced, but the chirping is still there. I've taken it to the dealership, my SA has acknowledged the sound, but says that the shop foreman couldn't replicate it. Somebody HELP ME PLEASE! The noise is driving me insane!!!! |
03-22-2010, 08:17 PM | #2 |
36
Rep 433
I may have the same squeek, seems like it coming from one of the instruments - if I push down on the top of the binnacle it STOPS.
Dealer spent a "day" tracking to down and failed... |
04-21-2010, 05:17 PM | #4 |
18
Rep 71
Good God somebody help me with this. When I drive on the freeway, it's insane. "chirp chipchirpchirp chirp chirp chirpchirp."
I've stripped off the left side aluminum trim, light switch, instrument cluster, and lower kick panel and drove it around like that, but I still can't identify the source. Took it to the dealership, they said it's coming from spring mount due to aftermarket springs, but I know it's inside the cabin. I'm going crazy here... |
04-21-2010, 07:04 PM | #5 |
314
Rep 3,262
I had a rattle coming from the glass that covers the instrument panel. It I pushed on the glass, it disappeared. Since a few months it disappeared entirely...strange.
04-21-2010, 10:11 PM | #7 | |
Rep 247
It's Funseeker! I'm all about the good times!
04-21-2010, 10:35 PM | #8 |
108
Rep 931
LOL - my car has the ghetto foam fix there.
Also had an intermittent creaky/clicky rattle from the dash. This was worst in hot, dry weather as the a/c cooled the cabin and once started, would continue the rest of the journey. It could be stopped momentarily by pressing firmly on the top of the instrument binnacle, the top of the iDrive arch or best by the piece of dashtop trim between those two arches. Replacement of the iDrive screen didn't help, fiddling with the screws holding the binnacles and screen sort of seemed to briefly. On the subsequent visit, they apparently removed the instruments and iDrive screen and tightened up various screws behind the dash - no guarantees they said. Anyway, so far, it is all gone. Very happy indeed. Remains to be seen if it has also fixed the a-pillar click that happens for 5 minutes every fortnight during summer...
John
17 F87 M2 Pure - long beach blue 10 E91 320d LCI - space grey - black dakota - steptronic - innovations - 157s - front PDC - Konis 99 BMW Baby Racer - red; 05 Renaultsport Clio 182 Cup - French Racing Blue - Konis - Eibachs - Remus - Turinis |
04-21-2010, 11:45 PM | #9 |
45
Rep 1,754
For the OP == check your hood latches. If one is busted or loose, you will get exactly this noise! Happened to me, was driving me crazy, and believe it or not, the valet attendant at the dealership nailed it. He was getting ready to take the car into the shop (for HPFP replacment) and said "Is your hood loose?". Then he walked over and pressed on one corner, and damned if he hadn't found the squeek! One of the hood latches was broken.
6ixSpd6018.50 |
04-22-2010, 08:33 AM | #11 |
5475
Rep 8,821
Something worth mentioning.....a few weeks ago i hit a nasty pothole that bent two wheels on the passenger side. After that incident i had a LOUD squeak coming from the dash everytime i hit a sharp bump that drove me insane. it was very loud and sounded as if the passenger seat was loose etc... turns out if you open up the glove box the fuse box was touching something behind the dash causing the noise. I was able to bang on the bottom of my glove box to replicate the noise and stuff a piece of foam inbetween that area for my fix.
Now i'm having a weird rattle from the front of the dash area on certain days. started happening out of nowhere and comes and goes. Almost sounds as if its coming from where the windshield meets the dash. 50K car with 4K miles that rattles like a 80's civic. Nice.... Alan
04-22-2010, 08:51 AM | #12 |
262
Rep 5,018
Drives: VALNCYA
04-22-2010, 09:16 AM | #13 |
→сяuisiиg iи му вмш←
66
Rep 1,642
Drives: 2010 Space Gray 328i
I have SAME noises, WITH a rearview mirror that moves with the slightest breeze from the A/C as well.
SuPerMoD @ MassMonsterz.com
A "Happy" Owner of a Metallic Space Gray 2010 BMW 328i ProGaMeR on the XboX 360 |
07-15-2010, 12:53 PM | #14 |
18
Rep 71
AAARRRGGHHHHH!!!!! With the warmer temps in So Cal now, this is driving me insane!
I've pulled out the entire instrument cluster, driver's side and center trim, headlight switch, and lower kick panel, and I've driven it around but I still hear the chirp. It sounds like two plastic or metal piece rubbing. Every little rut and groove in the road will set it off. Sometimes when my engine is idling rougher with the AC on it will set it off. Somebody help me! It's not the hood, not the instrument panel plastic, not the trim, could it be in the steering column when the dealership replaced it? |
07-15-2010, 02:02 PM | #15 | |
448
Rep 2,032
Drives: Red Flyer
07-15-2010, 03:37 PM | #16 | |
18
Rep 71
Also removed the A-pillar airbag trim, but not there either. This sucks. Since the dealership is claiming it's the aftermarket springs on the perch, I'm going to need to pay to have my stock sport springs put back in before my CPO warranty runs out. Probably not even covered by the CPO warranty. |
07-15-2010, 04:53 PM | #17 |
Rep 135
It's possible that they didn't screw in some bracket correctly, that's what happen to my car, and when it gets hot, the squeak drives me nuts. Fortunately my squeak was coming from the passenger side, so they pulled the glove box and had someone poke around inside while driving, and was able to locate the problem.
I say take your car in and replicate the situation, and hope for the best. |
07-15-2010, 05:28 PM | #19 |
253
Rep 7,089
Drives: '06 AW 330xi
Are you sure it's not your AC blower? They're known to get water in them and cause squeaking/eventually fail. The seal on the lower part of the windshield lifts and allows water to leak through.
07-15-2010, 05:31 PM | #20 | |
7
Rep 102
I think it's all a matter of road condition and the stiffness of the car. Especially with stiffer suspensions and lower profile tires, it's just going to add more stress to the car. I have just come to except the rattle as part of ownership for a sportier car... |
07-15-2010, 08:09 PM | #22 |
***** noob
1372
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Could be a number of things
Take out the cabin air filter and check any loose parts inside the vents Check under the steering wheel area where your dead pedal is located....its actually right above the dead pedal. You' ll see some plastic parts, check there
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
