Google maps send to car
03-17-2010, 09:28 PM | #2 |
CHEAT TO WIN!!
99
Rep 1,350
03-17-2010, 09:46 PM | #3 |
Rep 83
It does work in Canada if you have iDrive, at least on my 09 model. Just call BMW Assist they should be able to help you. They will need to have your email address on file for it to work.
That being said, not every location sent makes it through to the car. It works about 80% of the time for me. I also don't think it works if your car is parked underground. |
03-18-2010, 06:48 AM | #4 | |
109
Rep 1,043
it works for me to i have a 08 |
03-18-2010, 09:25 AM | #5 |
1274
Rep 4,703
FYI... If you do send something and it does not make it to the car for whatever reason you just have to call up the folks at bmw assist. They have all the items you send on record and can re-push it to the car for you. Much easier than going back to your computer to re-send it yourself
03-18-2010, 09:39 AM | #6 |
36
Rep 569
Drives: X5 35i Luxury, C450 AMG
You can send street addresses to your iDrive through 2 ways: Google Maps or BMW Concierge.
For Google Maps, you need to search the address you want. Then click send to car. You will need to enter the email address that you have given BMW Assist. This should work...if you just picked up the car, it does take a week or so for Google Maps to work in your car because they have to activate all the services for BMW Assist. BMW Concierge- just select this in your BMW Assist menu and you'll speak to a BMW representative. Just tell them where you want to go and they'll beam it to your car. All addresses regardless of which method you use will be stored in Messages. You can identify which one is which because each message will say either "Google Maps" or "Concierge".
2015 BMW F15 X5 35i Luxury
2016 Mercedes C450 AMG |
03-18-2010, 09:40 AM | #7 | |
Rep 83
03-18-2010, 09:51 AM | #9 |
43
Rep 608
Ok I picked my car up Mar 1. Been 2 weeks now and this hasnt worked yet. I remember when I picked up my car we used the SOS to setup BMW Assist. I will call them again and see whats going on.
03-18-2010, 09:59 AM | #10 | |
1274
Rep 4,703
I had a similar issue when I first got my car and did the assist activation. The tech on the phone had me run the update and the car picked up the necessary services. |
03-18-2010, 10:01 AM | #11 |
43
Rep 608
Ha let me run out to the car now and check... BRB....
No update services. However when I go to BMW Assist it tells me it is active, and what options I have...etc Last edited by teamadobo; 03-18-2010 at 10:11 AM.. |
03-18-2010, 10:12 AM | #12 |
1274
Rep 4,703
03-18-2010, 10:27 AM | #13 |
Rep 103
I use it on a daily basis for work. Works perfectly for me
09 Space Grey 335i Sedan
Packages: Executive/M-Sport/Navigation/Audiophile |
03-18-2010, 05:12 PM | #14 |
43
Rep 608
Problem solved. Turns out I was registered but for some reason the system took the wrong email address. They changed it and now its working fine. This is very cool and so convenient.
Thanks for all the replies. |
03-18-2010, 07:27 PM | #15 |
22
Rep 219
Drives: 2009 328xi Coupe
hmm.. does it work for non-idrive bmw assisted cars?
03-19-2010, 09:05 AM | #16 |
68
Rep 896
Drives: 2021 X5
That is so cool. I didnt realize I can do that. I just called and spoke to them and told me what I need to do. Pretty slick!
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black |
03-19-2010, 09:16 AM | #17 |
383
Rep 7,952
yea it works really well as you can have someone else send it while you are on the fly...for example you're just crusin and your buddies want you to meet em at a patio you've never been to before. dont even need to input into your GPS. just have em send it directly to your car and BAM
