Installing rear alloys on the front
03-16-2010, 09:48 AM | #1 |
10
Rep 153
hey guys,
is there anything wrong with having a set of rear 9j alloys on the front of a e92 m sport? thanks aram |
03-16-2010, 10:41 AM | #3 |
1545
Rep 8,972
Its a bit wide on the front, the offset will be slightly out too if its a rear wheel.
Are you fitting wider rears then? 9J all round will give and odd handling balance (if they fit anyway) |
03-16-2010, 02:30 PM | #5 |
Rep 72
hi, 9J is 2 wide. Even though you may be able to fit them. The tyre size will be incorrect for the width of the alloy wheel. 9J wheels will need something like 255 or 265s tyres. You can put 235,225 or 245s but what you will find is that they do not cover the edge of the alloy. The adverse effect is that they will be prone to damage. Stick with 8J..
03-16-2010, 02:48 PM | #6 |
268
Rep 9,915
Drives: VW T5
Hartge 20" alloys are 9j front ET40 with a 245 wide tyre, so if the ET is correct you should be ok I would think.
03-16-2010, 03:49 PM | #7 |
8
Rep 243
Drives: F31 330d M Sport
Why?
F31 330d M Sport
Previous Cars: E36 318is Coupe, E46 323ci, E46 M3, E92 325d M Sport |
