Thoughts on my V4 Log
03-15-2010, 07:20 AM | #1 |
69
Rep 1,137
This is a log I took yesterday starting at 3rd. Let me know what You all think and any adjustments you would make. You will notice 3rd gear is a little strange due to traction loss, spun most of the way throgh 3rd.
Car running stage 3+ MT maps on 6AT car with mods in Sig. IC is 100%, UT 100%. Thanks!
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
03-15-2010, 10:14 AM | #4 |
656
Rep 10,587
thats a good problem, having little traction in 3rd gear and up is no fun at all, flat out dangerous.
03-15-2010, 10:18 AM | #5 |
she likes the flavor......
85
Rep 1,622
Warning NOOB question ahead:
What exactly are we looking for when looking at these data logs? What do you look to determine that things are going well or not? What is the acceptable range for each of the parameters?
E92 Montego Blue silfa718 ..::STETT CAI|ADVAN RS|WAGNER FMIC|MS DP|VANGUARD|PROCEDE|FORGE DV|BMS OCC|KWV2|MICHELIN PSS|OOS::.. |
03-15-2010, 11:28 AM | #7 |
69
Rep 1,137
i went back to see if I logged CAN actual advance and I did not I have 3 laptops and the one I used was set up with the channels set up the way Shiv had set up. I will get some more logs this week with the CAN actual advance.
03-15-2010, 11:30 AM | #8 |
69
Rep 1,137
I have been running MT maps since I'm not a big fan of how much boost tappers off with the AT maps. I personaly haven't had any issues, but I have heard others have had misfire codes thrown at the top of the RPM band.
03-15-2010, 03:53 PM | #9 |
7
Rep 320
Basically ign. advance, throttle closure, and boost stability/response to throttle input; mainly though you need ign advance to check for knock but the OP forgot to post/log that haha..next time i guess.
03-15-2010, 04:10 PM | #10 |
35
Rep 1,084
Do we still need to worry about these things with the Autotune feature Shiv is working on?
_________________________________________________
09 E90 LCI Msport, European Delivery |
03-15-2010, 05:21 PM | #11 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
OP- Your logs look fine. But jp is right, you should add some more useful channels to the log such as actual throttle and actual timing. |
03-16-2010, 06:26 AM | #12 | |
69
Rep 1,137
