TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Replacment bulb halogen headlamps! 320i
      03-10-2010, 03:32 PM   #1
jmax1978
Drives: 320i 2006 E90
Hi
I want replace the bulb of my E90 320i car has , the current (original) ones works perfect but the lights are so yellow and want swap bulb with a more white , i was thinking buy the H7 extreme white from PIAA but i am afraid to create a error on the computer putting something not Original by factory , any advise to change to a more white light and just plug and play? also want have the same light on my fog lamps .... hope someone can help me in this issue , i dont want spende $70 dollars if i will have problem with the system of my car.
Thanks
      03-10-2010, 06:14 PM   #2
SV Concepts III
375
Drives: BMW Duh
You will want a 55w H7 replacement bulb. So long as it conforms to the factory rating, you will not get error codes or risk the factory housing/wiring.
One option are the Xenesis Tru Match bulbs which are a hyperwhite replacement. You won't get a true xenon match from a halogen bulb but they will be whiter than stock.
      03-11-2010, 09:24 AM   #3
E92-Lighting
E92-Lighting's Avatar
Drives: Next Generation LED Lighting
Originally Posted by jmax1978 View Post
Hi
Thanks
your car type needs H7 55W for DRL to be error free since that is what your running now. secondly, i wouldn't recommend PIAA's as they are way over-priced and performance ratio to price isnt worth it.
your fog lights are H11 55W. its probably best to get the same brand for perfect matching. in this case, MTEC super whites would be a perfect match to OEM, but pure white with no yellow like stock
      03-11-2010, 09:50 AM   #4
Mike@F1 Autohaüs
Mike@F1 Autohaüs's Avatar
195
Drives: ❤
Any hyperwhite bulb will work fine and not cause any errors as long as it's the same wattage as OEM
      03-17-2010, 11:54 AM   #5
jmax1978
Hi
i change them and work wonderfull i am damn happy how they look , so white and clean .. will send pictures , but i make a mistake i just brought
Low beams = Xenesis tru Match H7 1 set (2 bulbs)
Fogs Lights = Xenesis tru Match H11 1 set (2 bulbs)
but i forgot buy for High Beams
can any help me with what i should buy? they use the same H7 or another number?
Hope i can get answer soon!!!
      03-17-2010, 12:02 PM   #6
Mike@F1 Autohaüs
195
Drives: ❤
High beam = H7
      03-17-2010, 01:54 PM   #7
SV Concepts III
375
Drives: BMW Duh
Hi
Yep high beams are H7.
