BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > BMW 16" Steel Winter Rims
      11-07-2006, 03:30 PM   #1
hmalekib
Drives: 2008 135i
I have for sale a set of BMW 16" steelies... Asking $150 OBO for the set.
email hadi.maleki@iteraweb.com or call me at 647-891-9370.
Local GTA pickup only.
      12-03-2006, 09:45 PM   #2
Rally guy
Happiest Sideways
Drives: 2011 328xi, had 2006 330xi SGM
Will 16's fit on a 330xi? (With 17's stocK)??
Can anyone confirm? Looking for a set for winter tires.
Thanks,
RK
      12-04-2006, 01:02 AM   #3
GregL
GregL's Avatar
98
Drives: 2016 CLA45 AMG
Thanks,
RK
No, 330's need a 17" rim minimum to clear the larger rotor and caliper. 323's and 325's can accomodate 16" steel wheels however. Also BMW does not recommend the use of 17" steelies in any case as they say that the limited airflow does not provide adequate brake cooling.
I myself bought a set of replica E39 M5 wheels with snow tires for the winter. http://www.e90post.com/forums/showthread.php?t=33883
It's worth checking out whats available from 1010Tires.com or TireTrends.com. Both are based out of BC and have good prices, you can find 17" alloy rims compatible with our cars for around $150 a piece if I'm not mistaken.
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone
2010 Mercedes-Benz C350 4Matic - Gone
2006 BMW 330xi - Gone
2001 Infiniti QX4 - Gone
      12-04-2006, 12:53 PM   #4
MOAB
MOAB's Avatar
18
Drives: Porsche & BMW
Originally Posted by GregL
No, 330's need a 17" rim minimum to clear the larger rotor and caliper. 323's and 325's can accomodate steel wheels however. Also BMW does not recommend the use of 17" steelies in any case as they say that the limited airflow does not provide adequate brake cooling.
Is the same true for the E90 335i? I just ordered mine last Saturday and am hoping my 17inch snows from my 330ci will fit this car. The dealer wasn't sure if 17inch tires would fit, but that makes no sense to me.
      12-04-2006, 03:55 PM   #5
SaskE90
SaskE90's Avatar
13
Drives: titanium silver 325i
Well the 335i does have bigger brakes then the 330i so there could be a hance they don't fit. hopefully that won't be the case
2006 E90 325i, Titianium silver, 6MT, Black interior, Aluminum trim, ZSP, ZPP.
      12-13-2006, 01:23 PM   #6
Hawkshaw
Hawkshaw's Avatar
100
Drives: X3 xDrive28i
2006 330i  [0.00]
The 17" tires shouldn't be a problem, but if you've got 17" steelies, then you may not be able to use them. Every source I talked to (dealership, tire dealers, this forum) says that steelies should not be used on the e90 330i w\ sport package.
However, if you trust your dealer and they say it'll work, then go for it. I ended up paying just over $1800 (including taxes (14% here) and shipping) for these --> http://www.e90post.com/forums/showthread.php?t=39207
Paul
