Engine problems on 335i
02-26-2010, 02:35 PM | #1 |
146
Rep 898
Drives: F90 M5
My 2008 335i E92 started playing up today. I started it this morning and it started to rumble and shake. After a few seconds the yellow engine light lit up (not in the center status display where the time and outside temp are, but to the top left of the tacho). There was a strong gas smell and it was sounding like an old V8 on carbs.
I started to drive it to the dealer and there was very little power and it was very rough. Halfway to the dealer (about 2 miles) the idle evened out and the engine light went off. It's been fine since. The dealer can't look at it until March 10th What could this be? I know a lot of people will say HPFP but we don't really have that issue over here in the UK as our fuel has much less ethanol than the US. The starting cranks are always short as well. My dad's 320i had similar symptoms 6 months ago and that was a bad coil pack - could it be that or are the engines so different that this is unlikely?
F90 M5 (Marina Bay Blue, M Performance Parts)
Previous: F82 M4 / F20 125d M / E92 335i M Ind / E90 325i SE / E46 318i SE / E36 316i |
02-26-2010, 02:41 PM | #2 |
45
Rep 1,754
coils, injectors, HPFP (yes, they do fail other than in the US), sensor, who knows?
Don't you have another dealer you can go to who can take a look at an ailing car without a two-week wait? That's ridiculous -- I'd show up on his doorstep demanding he cover the rental, if that happened to me. |
02-26-2010, 02:43 PM | #3 |
158
Rep 3,158
See if this re-occurs, specifically with a cold engine....
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
02-26-2010, 04:20 PM | #4 |
Polytech Trooper
44
Rep 190
Drives: 2018 F36 440i Gran Coupe
something similar happened to me too...very similar symptoms as you described...especially when starting up after the car's been idled in low temperature..
took it to the dealers, they replaced... some injectors or what not.. . have them take a look at it. it took them 2 bus. days to fix it.
Drive w/ Passion Bucket!
02-26-2010, 05:04 PM | #6 |
146
Rep 898
Drives: F90 M5
I'll update this thread when I try and start it up from cold tomorrow and see what it does
02-26-2010, 05:11 PM | #7 | |
Sensei
52
Rep 1,054
02-26-2010, 05:15 PM | #8 |
Rep 131
I had the same issue with my 09 E90 335i and still have it.
Repairs so far: HPFP All injectors All coils All plugs Valve seals (That nearly fixed it) I'm in the process of a trade assist. Good Luck! LJS330i |
02-26-2010, 05:23 PM | #9 |
45
Rep 1,754
02-26-2010, 06:55 PM | #10 |
8
Rep 278
if its was running rough and sort of stumbling and a smell of gas then you have fuel which should mean the HPFP wasnt cutting out and if your smelling fuel then its not being burned which sounds like a spark issue. Thats just my $0.02 though GL and let us know
02-27-2010, 05:32 AM | #11 |
146
Rep 898
Drives: F90 M5
Started it up this morning and it was fine, which is quite annoying as it looks like it's going to be one of those intermittent things that can never be replicated.
A year ago the car went into limp mode and the error code related to the fuel pump but they just cleared the code and the problem never reoccurred.
02-27-2010, 05:47 AM | #12 | |
1706
Rep 14,829
The dealership isn't stupid, either, they probably know officially that BMW does not know what's going on with 335's, and they probably cannot fix the root cause. I too have an appt. in March. It would be quite interesting if when the N55 starts selling, it has zero problems. |
02-27-2010, 05:49 AM | #13 |
Rep 131
02-27-2010, 05:54 AM | #14 | |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
02-27-2010, 06:55 AM | #15 | |
12
Rep 301
What makes you think the N55 will be any better? It will also have an HPFP, direct injectors, coils, etc. |
02-27-2010, 07:02 AM | #16 | |
1706
Rep 14,829
My wife took a pic the other night of my dash with the lights lit up--also, you can see I'm driving due to the tach and speedo. Upon restart, the lights are all gone. This is the 3rd time, it's like I know the drill. BMW claims the N55 is way better--is it lowered costs, or is it reliabilty?? Seems like their trend is to lower costs and charge more for the product. It's not like their sales are so good that they could afford to R&D and come out with a better design. |
02-27-2010, 11:37 AM | #17 |
1591
Rep 4,553
And you think the N55 won't have its own set of problems??? For the most part N55 appears to be cost reduced N54 with valvetronic (some emissions improvements and slight fuel economy improvements). Since its 2nd gen it could have higher reliability or it could be the same thing all over again. Time will tell.
02-27-2010, 11:46 AM | #18 | |
1591
Rep 4,553
02-27-2010, 11:49 AM | #19 | |
146
Rep 898
Drives: F90 M5
I drove it 2 miles on a cold engine with strong fuel smells in the car - if that unburnt fuel made it to the catalytic converter how will the damage manifest itself? Will it be immediate or will the cat fail after another year when i'm out of warranty?
02-27-2010, 11:51 AM | #20 |
28
Rep 946
I agree with this statement, it doesnt sound like HPFP but more like coil pack/injector issue.
02-27-2010, 12:04 PM | #21 | |
1591
Rep 4,553
Really, you have another year of warranty so keep an eye on it and see if the problem returns or if the fuel smell continues. My philosophy has always been to avoid mechanics whenever possible. Even with the better than average training BMW provides to techs, too many of them don't know how to assemble/disassemble and repair things properly. |
02-27-2010, 12:16 PM | #22 |
158
Rep 3,158
+1
--Mark Twain |
