Corona ring upgrade
02-26-2010, 06:51 AM | #1 |
77
Rep 879
Corona ring upgrade
I can't see this covered elsewhere...
If I go ahead and change the bulb to an LED, how will the bulb behave when I unlock the car? At the minute the bulb brightens grdually until fully lit, if I put an LED in there, will it either be on or off ie no dimming? Thanks |
02-26-2010, 08:20 AM | #3 |
306
Rep 7,433
That's not correct. LED's will not dim as you lock/unlock the door. They will simply turn on and turn off. If they're cold, they may briefly flicker. It's pretty common. If you search "angel eyes" this has been covered in depth because a lot of people have asked this question
02-26-2010, 11:48 AM | #4 |
375
Rep 17,017
LEDs do dim, just at a different rate than halogens. Our WeissLicht LEDs will function like your factory bulbs so they will fade on and off when you lock/unlock the car.
