02-17-2010, 01:50 PM | #1 |
254
Rep 4,048
▀▄ eas - Rogue Engineering - Performance Clutch Systems for your Z4M Roadster/Coupe
Gentlemen,
Rogue has been known to make excellent products for the E46 M3 world, so they've decided to move that along to the Z4M Coupes and Roadsters. With their products in current BMW Race cars, their race inspired clutches certainly exceeded that expectation. Rogue Engineering joined with JB Racing to bring you the most inclusive and highest quality line of clutch systems available. In the past, we have used multiple flywheel manufacturers, constantly improving the design and quality. JB Racing Lightweight Aluminum Flywheels are designed and manufactured to the same exacting standards and precision our customers expect and offer unique and significant features not found in competitive brands. There are significant benefits of an Rogue Engineering Performance Clutch System (PCS) over a factory dual-mass flywheel setup are numerous. Some benefits include: - Lighter total weight, allowing engine to more rapidly transfer power - Longer lasting friction materials - Elimination of SAC (Self Adjusting Clutch) mechanism on factory pressure plate - More consistent, predictable clutch engagement - Ability to handle more power than factory setup Specifications: - 10lb weight savings over factory e46 M3 system - CNC machined to factory dimensions for a exact fit - Replaceable, hardened, heat-treated steel friction surface - Helicoil inserts for pressure plate bolts (prevents bolts from stripping) - Enlarged dowel hole, like factory flywheel (where applicable) - Flywheel gaul plate and replacement 10.9 flywheel bolts - Replacement pressure plate bolts - Completely zero balanced - Manufactured to exacting specifications, to accept our patented semi-metallic backed sprung hub disc - Stepped dowel pins means that they can never come out! If your vehicle continues to have sluggish throttle response, poor acceleration, or is due for a clutch replacement, a Rogue Engineering Performance Clutch System can be your ticket to renewing more fun from your BMW! Rogue Engineering - Performance Clutch System (PCS) - Z4M-Roadster/Coupe http://www.europeanautosource.com/pr...oducts_id=2760 Models Supported: 2006-2009 Z4M Roadster/Coupe If you have any questions in regards to the clutch set up, please feel free to contact me directly via PM, email, or simply just give me a call to my extension. |
03-12-2010, 06:26 PM | #3 |
254
Rep 4,048
They're actually not the same, strangely enough. Part number for OE Clutch is only meant for M Roadster and M Coupes, not E46 M3's. You would assume they're the same right? Guess not.
03-12-2010, 06:41 PM | #4 | |
218
Rep 4,726
The diameter is the same obviously, I've been trying to figure out if the splin count for the input shaft was the same or not. I know the pressure plate and flywheel are the same. I'm trying to figure out if we are stock with the ZHP 6 speeds input shaft splines or not.
03-12-2010, 06:45 PM | #5 | |
254
Rep 4,048
