Another Will it Fit...
02-11-2010, 04:15 AM | #1 |
Gruppe Titan
262
Rep 2,839
Drives: 08 E92 SG/Coral
I have a E92 lowered to about HR Sport specs. I have 18x8.5 ET35 and 18x9.5 ET42 wheels. I'm using a 12mm spacer in the rear now, but can use any other spacer to make the right tire fit.
I am looking to run the widest tires without running problems with rubbing. Can I run 285/35/18 rear and what for the front? If not, what's the widest I can go?
02-11-2010, 04:19 AM | #2 |
161
Rep 7,377
you need a 10J to run 285 properly .
02-11-2010, 02:27 PM | #3 |
Gruppe Titan
262
Rep 2,839
So 275 is the max in the front and 245 front? What profile 35 or 40?
10-15-2010, 12:50 AM | #4 |
Gruppe Titan
262
Rep 2,839
Searching once again, will it fit.
10-15-2010, 11:26 AM | #5 |
475
Rep 13,583
Drives: JB E92 335i
18x8.5 ET35 with a 235/40/18 in the front and 18x9.5 ET42 with a 265/35/18 is the recommended setup. You may be able to fit the 275/35/18 tire depending on the exact size spacers your going to put on the wheel. Also, it's nothing that a simple fender roll can't fix in terms to get more clearance.
10-15-2010, 06:37 PM | #6 |
BimmerPost Supporting Vendor
2040
Rep 25,989
With the following widths, I would recommend running a 235/40/18 front and a 265/35/18 or a 275/35/18 rear. Though 285's can work on a 9.5" wheel, it is a bit wide and will balloon the side walls. A 10" wide wheel would work better for a 285 tire.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
10-17-2010, 12:51 AM | #7 |
Gruppe Titan
262
Rep 2,839
Went ahead and got 285/35/18 and going to play around with spacers/camber to see how it works out.
01-17-2011, 09:57 PM | #8 |
127
Rep 4,732
01-19-2011, 01:21 AM | #9 |
Rep 112
bump! wanna know how this went!
07 JB 335xi e90| jb3 2.0 | BMS DCI
04 Competition Orange SVT Cobra | 3,960 original miles | Kenne Bell 2.2 |
01-19-2011, 02:48 PM | #10 |
Gruppe Titan
262
Rep 2,839
Never got a chance to try the set up.
Sold my 18s but I got the tires if anyone's interested.
