BMW M3 Forum (E90 E92)
      02-09-2010, 10:37 PM   #1
jordanfox
jordanfox's Avatar
19
Drives: BMW
Request: VRS front lip installation guide
Hi guys, anyone here can share a VRS front lip installation guide (thru using self-taping screws and 3M tape)?photos & videos preferred....
very much appreciated..
      02-09-2010, 11:01 PM   #2
isabayo
44
Drives: G05 X5 50i M Sport
I dont have any photos or videos but its not very difficult at all. I only used self tapping screws and its still on there tight after several days of hitting ice and slush from the MD winter we're having here.
I used a bunch of blue painter's tape to hold the lip to the bumper, tape it as tight as you can from under the bumper up to the top of the bumper/hood. With it in place I just started to screw it into the bumper.
If you plan on using the 3m double sided tape, apply the tape to the contact area on the lip first then peel back a little bit of it before you do any of the steps above. when you secure it to the bumper with the painters tape just start to peel back the red backing little by little while adding pressure to ensure a good bond.
      02-09-2010, 11:15 PM   #3
jordanfox
jordanfox's Avatar
19
Drives: BMW
thanks a lot... How many screws did you use? all eight? I am planning to use screws on two sides and use 3m tape on the middle part. dont wanna drill on the middle part of the bumper . Hope it will work..
      02-09-2010, 11:21 PM   #4
isabayo
44
I put screws into all the screw holes. I think that will work, 3m tape when put on a clean surface is STRONG.
      02-10-2010, 10:02 AM   #5
bavarian19
bavarian19's Avatar
Drives: Car
I use 3M tape to hold on my aero lip with the screws on the side. No problems at all.
      02-10-2010, 12:58 PM   #6
SV Concepts III
374
Drives: BMW Duh
Yep, 3M tape across the front and bolts underneath will do the trick.
      02-10-2010, 02:41 PM   #7
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
I just used screws alone, and it's held up very nicely with no gap at all.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      04-05-2010, 08:04 PM   #8
BruinE90
BruinE90's Avatar
Taiwan
12
Drives: 2009 E90 M3
will the holes be visible when the lip is removed?
      05-10-2010, 09:06 PM   #9
edcvin
edcvin's Avatar
Drives: 2006 M5 | 2011 M3 | 2020 X3M
I have the vrs poly lip. On the middle section, there holes on the bottom strip yet there are no holes on the top part. Is that normal? Also do you have to drill through and put it into the bumper? The car is currently at the bodyshop and we aren't sure being that I got no instructions with the lip.
Thanks,
Vin
      05-11-2010, 04:34 PM   #10
Kenyon
Drives: BMW
Have a second set of hands to help line it up and hold it while you use self taping screws and screw them in.
Search this Thread:
Advanced Search
m3post
