engine malfunction
02-09-2010, 09:55 PM | #1 |
Perfect
43
Rep 543
engine malfunction
I have done some research on the forum but there isn't much relevant information about this issue.
Basically, I tried to pull my car up to speed limit on a road (of course no traffic, no people, and I just hit the speed limit and slowed down immediately). I tried it 3 times in different days, the engine light came out twice. it said "Engine malfunction, reduce power" on the screen. Then I can definitely feel the engine is reducing power. Then I restarted the car again, light's gone. Everything's normal. actually I pull it really hard twice and the light came out both times. The other time, I pull smoothly to the limit, no light came out. In daily drives, no matter how hard I pull it, as long as I didn't hit the limit, engine light won't come out either. Does this issue relate to HPFP?... if it does, will the dealer be able to fix it for me?. currently running on JB3.. thanks in advance |
02-09-2010, 10:07 PM | #2 |
219
Rep 8,375
Drives: Just a car
you need to use BT to scan and see what the error code(s) related to and go from there. Mike should be able to help you as well.
02-09-2010, 10:23 PM | #3 |
176
Rep 1,251
Drives: E92 M3
that happened to me couple of times when i was using V3 rev1
I never had any problem like these before the tune. I had some serious misfire during the 1 week I had the tune and now my car is back to stock and its still idling roughly sometimes and this morning 2 weeks after i removed the tune I had misfire in cylinder 1 & 2 and engine just shut itself off too. Going in for service this week.
2013 Scion FR-S
2009 BMW E92 M3 2008 BMW E90 335i 2005 BMW X3 3.0i |
03-02-2010, 08:35 PM | #4 | |
24
Rep 59
Went away immediately upon restart. Have you had any issues since? ==EDIT== Now I just feel silly. You said pulled to the speed (I thought you meant car's speed limit). That is what happened to me. I hit the limiter or governor, i.e. 140ish. I should read more carefully.
2024 M3 Comp. X-drive, BSM + Kavaca stealth PPF
Mods: Vorsteiner grille, MHC+ CF skirts & badges, MAD mid-pipe & SST valve controller, M.Perf. splitter. Last edited by stikya; 03-04-2010 at 07:08 AM.. |
03-02-2010, 08:45 PM | #5 |
$*~TIVU EMPIRE~*$
124
Rep 2,194
+ 1
Retired: 08 E92 335i |
03-02-2010, 10:13 PM | #6 | |
Perfect
43
Rep 543
03-02-2010, 10:44 PM | #7 |
130
Rep 5,040
you need to pull the code, but from experience, its probably an overboost code 30FE I think and 3100, which is boost pressure deactivation. Solution - update to JB3 2.0; it has cold weather fixes implemented
03-03-2010, 07:27 AM | #8 | |
24
Rep 59
Mods: Vorsteiner grille, MHC+ CF skirts & badges, MAD mid-pipe & SST valve controller, M.Perf. splitter. |
03-04-2010, 12:47 AM | #9 | |
153
Rep 3,868
Drives: E93 335i
I wouldn't be surprised if you run BT scan the code you tripped is 30FE: Exhaust fume turbo charger, high pressure side Error will not cause a warning light Error is not currently present Test conditions have been completed 3100 boost-pressure control, deactivation Error will not cause a warning light Error is not currently present Test conditions have been completed
12.770 @ 112.81 mph||slip||JB4|FMIC|DPs|DCI|N54 DVs|ER CP|Koni FSD|Eibach-Pro|F Strut-bar|R Sway-bar|Hankooks V12|DPE SP16|BBK|15%Tint|CF Front Lip|CF Diffuser|M3 Spoiler|SmartTop|LUX AE|Debadged |
03-04-2010, 04:08 AM | #10 |
81
Rep 2,017
I had this problem a while ago dealer replaced all injectors ignition coils and the famous HPFP...
F30 335i Xdrive Black Msport
E92 335i Black/black (Missed) |
03-04-2010, 02:50 PM | #11 | |
Perfect
43
Rep 543
03-04-2010, 06:01 PM | #12 |
153
Rep 3,868
Drives: E93 335i
If you're coming out to Mar 6th Dyno/BBQ meet get him to scan first to see what are the actual codes were logged. I was running into this problem with Ver 1.4 software.
