stripped lug
02-08-2010, 10:40 PM | #2 | |
ocasionally in crisis
52
Rep 2,358
Bring it to a place that does various types of welding. They will basically weld a large nut or bolthead onto your lug nut and then take it off that way. Beware: mig welding may not work - u may need a higher heat type of welding. Also u may damage your rim from the welding so u may have to (spot) repaint. OR maybe a good mechanic or machine shop and drill out your lug nut and use an e z out to remove the stripped nut ? Good luck.
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
02-09-2010, 12:09 PM | #4 |
30
Rep 679
how bad is it stripped? See if you can try this, tighten the other 4 lugs slightly tighter than the stripped one. This will relieve some pressure on the stripped lug, then try to take it off. If not contact your local machine shop, maybe they can drill a hole in it and tap it out or something. I wouldn't go directly to welding on it
