10-29-2006, 05:28 AM | #1 |
Texas
311
Rep 769
What happened to the 528i / 535i?
When I saw that the E90 325i / 330i sedan was being upgraded to a 328i / 335i respectively, I immediatly thought the 5 series would have the same treatment, but I haven't seen any announcements yet. I seemed only logical, since they were sharing the same engine.
10-29-2006, 05:35 AM | #2 |
1312
Rep 10,185
It takes time for engine changes to filter through to different models
Next possible slot for a change is March 2007 production, and March production has been a engine change time for 5 Series before Remember the 5 Series facelift is also due next year, and usually the facelift gets new engines
BMW if you are reading, I need a job, Please. Last edited by E90Fleet; 10-29-2006 at 07:31 AM.. |
10-29-2006, 06:12 AM | #3 |
Moderator
7517
Rep 19,368
The 5 series probably has to wait for a suitable V8 replacement also, since its likely that an E60 with the 3.0L N54 engine will offer performance veyr near that of the 4.8L N62 powered 550i. On paper the N62 offers a 20% advantage in power and torque. But peak RPM is higher. And the bigger factor is that the 550i weighs much more than its inline 6 powered sibling, the 530i. If you put the N54 in the E60 to make a 535i, it will increase weight a little over the 530i - yes. But not more than 100 lbs probably. The extra weight the 550i carries will negate most of the advantage of the V8 over the turbo 6.
Word is a turbo'd V8 is coming to aleviate all of this. I don't think the timeframe is known though. In the meantine, maybe they can bump the N62 to 400+ hp (perhaps with a displacement increase)? |
10-29-2006, 07:30 AM | #4 | |
1312
Rep 10,185
BMW if you are reading, I need a job, Please. |
10-29-2006, 07:42 AM | #5 | |
10
Rep 369
Next in line will be the 535 getting the 3.0 litre bi-turbo I-6. Possible MY2007/2008 US line up: 550i with the bi-turbo 4.4 V8 535i with the bi-turbo 3.0 I6 528i with the NA restricted 3.0 I6 |
10-29-2006, 07:47 AM | #6 | |
40
Rep 470
10-29-2006, 07:53 AM | #7 | |
1312
Rep 10,185
Its believed the facelift 5 Seres would just get a uprated V8, not the turbo one.
