front strut assembly/rear shock mounts
01-28-2010, 05:43 PM | #1 |
17
Rep 306
Does anybody have the part number for the 'top hat' that goes on the front strut assembly to connect it to the chassis?
I'd prefer not having to take the OEM strut assembly apart (as that would involve compressing springs) to be able to install coilovers. Instead I'd like to be able to swap in and out with ease. I am hoping it will make the installation process easier if I can have a shop mount my springs onto the front struts and assemble them - that way I can just pop them in. In addition - are upgraded rear shock mounts recommended with the e9x? If so, what brand? |
01-28-2010, 06:48 PM | #2 |
Rep 76
You need:
2 Guide support (upper mount) 31306775098 $125.53 2 dust collar 31331110196 $1.84 2 flat washer 31306763966 $4.24 2 upper spring plate 31336764093 $11.70 2 upper spring pads 31336767500 $2.23 2 Additional shock absorber, front (bump stops) 31336767333 $19.48 2 dust tubes (shrouds) 31331094749 $3.76 2 lower spring pads 31336764372 $1.85 You can buy camber / caster plates and bumpstops for just a few more bucks |
01-28-2010, 09:10 PM | #4 |
AutoXer
34
Rep 683
I'm guessing JM3 will help you out. He is from Ground-Control. They have 3 different ones for the E9x cars.
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
09-01-2010, 01:07 AM | #5 | |
Rep 7
parts
09-01-2010, 05:33 AM | #6 | |
37
Rep 2,084
09-01-2010, 12:16 PM | #7 | |
1821
Rep 5,337
Camber and Caster adjustable. TC Kline: Camber and Caster adjustable with Heim joint. Ground Control: Camber adjustment only. Uses some stock mounting hardware and isolation. Out of the list I'd prefer Vorschlag for my PERSONAL NEEDS. But any of the three will be more than adequate for what you wish to accomplish. |
09-01-2010, 12:24 PM | #8 |
1821
Rep 5,337
As for upgraded rear shock mounts, there's really no magic to it. The only thing that is worth upgrading on the shock mount is the ability to remove the shock from underneath the car. Companies like Vorschlag, Rogue Engineering, TC Kline, Ground Control all make an upgraded shock-mount with the crescent bracket that allows you to mount and dismount the shock from underneath the car rather than having to remove the interior trim in the trunk to get to the bolts. Just keep in mind, ANY upgraded shock mount material, especially anything harder than the typical urethan material, will make noise. Lots of noise. Especially bearing type replacement for race cars.
09-01-2010, 12:31 PM | #9 |
Supreme Allied Commander
3861
Rep 54,424
Drives: F80 M3
09-01-2010, 12:32 PM | #10 | |
3861
Rep 54,424
Drives: F80 M3
09-01-2010, 02:13 PM | #11 |
37
Rep 2,084
Dinan rear shock mounts are firmer and also shallower to add 10mm more travel. They make a very noticeable improvement in ride quality.
09-01-2010, 05:14 PM | #12 |
1821
Rep 5,337
09-01-2010, 05:26 PM | #13 | |
226
Rep 2,387
http://www.realoem.com/bmw/showparts...67&hg=31&fg=10 |
09-01-2010, 05:34 PM | #14 |
3861
Rep 54,424
Drives: F80 M3
Do you also realize that the oem load cushion(the bottom half of the mounting bushing) and rebound cushion(the top half of the mounting bushing)will crush to similar thickness as the Dinan version? The amount of crush is determined by the height of the spool, which are the same between the oem and Dinan. I don't see any potential gain in travel unless a shorter bump stop is used, at least not in the the 135/335/M3 without EDC. I have not seen the M3 EDC rear damper in person so I can't say whether travel is improved on that damper or not.
09-01-2010, 07:44 PM | #15 | |
37
Rep 2,084
09-01-2010, 08:46 PM | #16 | |
3861
Rep 54,424
Drives: F80 M3
Here is my reasoning... The small amplitude motions with very high frequencies are met by both the load and rebound cushions. Larger amplitude motions from the suspension affect the cushions much less because their compliance is very small or have very little deflection. The larger amplitude motions, such as roll and pitch are control by the dampers. The potential for the Dinan cushions to give you improvement in ride quality is minimum if any in my opinion. Maybe "Orb" would like to say something here... |
09-02-2010, 05:39 AM | #17 |
37
Rep 2,084
^^ Well it is easy enough to try. Besides me, I have only seen one post here from someone who installed Dinan rear shock mounts as a separate increment. He tried them on my advice and reported the same results. The difference it makes is not as big as say rear subframe bushings. It is about one-third to half that big a difference, but it is a completely positive improvement with no downside.
09-02-2010, 12:26 PM | #18 | |
3861
Rep 54,424
Drives: F80 M3
It is easy enough to have them made from a rubber or urethane of higher durometer rating than oem. Perhaps I can engineer something that actually add compression travel. |
09-02-2010, 05:41 PM | #19 | |
37
Rep 2,084
BTW are you planning an M3 Strut Tower Brace kit for 135i? |
09-02-2010, 09:34 PM | #20 | |
3861
Rep 54,424
Drives: F80 M3
Yes, we are thinking about making the kit - CNC or cast, neither one is cheap. The other solution is just a modfied M3 unit, which is what is on the car now. |
10-19-2011, 05:42 PM | #21 | |
25
Rep 423
Drives: 2007 328i, 1998 328i
The stock cushions are made out of a material very similar to what bump stops are made out of, whereas the Dinan cushions are made out of rubber.
2007 328i ZSP. M3 suspension: custom valved Bilstein shocks, Hyperco race springs, M3 lower control arms front and rear, M3 sway bars, and M3 subframe bushings. E46 front guide supports. Euro tail lights.
10-19-2011, 10:46 PM | #22 | |
3861
Rep 54,424
Drives: F80 M3
