SES light on... then 24 hours later off?
01-27-2010, 09:20 PM | #1 |
923
Rep 15,818
My SES light was on last night when I turned the car on (7:25 PM) and today (8:15 AM and 1:30 PM)
However, it turned off tonight (6:20 PM) I finally had a chance to scan the car These are the codes that appeared: 2CAB: 2CAB Lambdaprobe 2 before catalyst, temperature Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption Freeze Frame Information Event 1 Odometer 17504kms 10876miles symptom Lambda probe heating in front of catalytic converter bank 2 1.00 0-n Battery Voltage 13.06 V Lambda probe heating in front of catalytic converter bank 2 81.25 % voltage Lambda probe in front of catalytic converter bank 2 2.71 V Event 2 Odometer 17504kms 10876miles symptom Lambda probe heating in front of catalytic converter bank 2 1.00 0-n Battery Voltage 14.34 V Lambda probe heating in front of catalytic converter bank 2 67.19 % voltage Lambda probe in front of catalytic converter bank 2 2.03 V Event 3 Odometer 17504kms 10876miles symptom Lambda probe heating in front of catalytic converter bank 2 1.00 0-n Battery Voltage 14.08 V Lambda probe heating in front of catalytic converter bank 2 71.09 % voltage Lambda probe in front of catalytic converter bank 2 2.30 V 2CA7: 2CA7 Lambda probe heating in front of catalytic converter 2, function Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption Freeze Frame Information Event 1 Odometer 17504kms 10876miles symptom Lambda probe heating in front of catalytic converter bank 2 1.00 0-n Battery Voltage 13.06 V Lambda probe heating in front of catalytic converter bank 2 81.25 % ceramic temperature Lambda probe in front of catalytic converter bank 2 0.00 °C Event 2 Odometer 17504kms 10876miles symptom Lambda probe heating in front of catalytic converter bank 2 1.00 0-n Battery Voltage 13.82 V Lambda probe heating in front of catalytic converter bank 2 31.64 % ceramic temperature Lambda probe in front of catalytic converter bank 2 0.00 °C Event 3 Odometer 17504kms 10876miles symptom Lambda probe heating in front of catalytic converter bank 2 1.00 0-n Battery Voltage 14.34 V Lambda probe heating in front of catalytic converter bank 2 28.91 % ceramic temperature Lambda probe in front of catalytic converter bank 2 0.00 °C My current mods: JB3 1.4 Beta map 5 on 91 octane daily RR DPs Helix FMIC BMS DCI RR charge pipe with Dual Diverter Valves RR Oil Catch Can I have a 2009 e93 335i with 10905 miles Had a HPFP failure at around 2700 miles if that means anything I was wondering if I should clear these codes.... or if it'something that BMW service needs in order to fix the car.. I have not done any WOT since the SES came on last night as I was scared of damaging something. Any help will be greatly appreaciated Thanks
01-27-2010, 09:32 PM | #3 |
159
Rep 5,689
contact terry about the v3, I had the same codes too with the old one and the new one cleared them right up.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(1addicts.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
01-27-2010, 09:38 PM | #4 |
923
Rep 15,818
I've had the RR DPs since like Octover
and the 02 Sims were install that day email has been sent to terry...
01-27-2010, 09:48 PM | #5 |
923
Rep 15,818
v3?
01-28-2010, 11:27 AM | #6 |
923
Rep 15,818
Terry said my o2 sim isn't a problem
but a bad 02 sensor..
01-28-2010, 01:39 PM | #8 |
923
Rep 15,818
Yes.
However, if you noticed in my other thread, i specifically stated that it would belong better in the General section as it is not exactly a 'Turbo' problem But, I don't know how to delete a thread... so I had nothing to do this with this one
01-28-2010, 05:15 PM | #9 |
106
Rep 728
Check out my thread here:
http://www.e90post.com/forums/showthread.php?t=344877 You'll see my codes are the same, except mine is bank 1 whereas yours is bank 2. Pretty sure it's a bad O2 sensor. I actually changed out BOTH pre-cat sensors just to be safe, but if you want to save $180, just change 1 out. Your mechanic should be able to determine which is bank 1 and which is bank 2. I'll post the how-to in my thread.
PROcede | AMS FMIC | AR Catless DPs | AR Oil Cooler | BMS DCI Wavetrac LSD | KW V3 w/ Swift Springs | M3 Front Suspension |
01-29-2010, 12:25 AM | #10 | |
923
Rep 15,818
Thanks bro! I'll read it in the morning Bit too tired after a 12 hour work day to read something long heh
