Boost response bad on turbos/fuel system?
01-27-2010, 05:38 PM | #1 | |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
The reason the boost responds so immediately and accurately has to do with the fact that we know exactly where the actual throttle blade is positioned at all times. So we never induce a very commonly experienced situation where the turbos are asked to blow against a closed (or partially closed) throttle blade. Needless to say, this is actually is far more stressful on the thrust bearings of the turbos than anything that we could possibly to do them ourselves. With a little research you may find that with v4, pre and post throttle boost pressure are almost always the same. This is because the DME is rarely forced to close throttle when reacting to a perceived overboost condition. You will also find that turbo wastegate DC, as an average is lower with v4, than it is with other tunes that run the same boost. Again, this is because we are not forcing the turbo to push against things (half opened throttle blades, for instance) that it doesn't naturally want to push through. And secondly, if a fuel injector that is designed to pulse several injections per engine event, can't react quickly to load changes that are caused by a someone large spinning wheel that has a thousands of times more inertia than the piezoelectric mechanism in the injector, someone screwed up. And lastly, one you experience what it is like to drive a turbo system that is properly optimized for response, there's no going back. It's easier and more fun to drive. And you can also run less boost and achieve the same amount of general performance. my 2c, Shiv |
01-27-2010, 05:53 PM | #2 |
Rep 200
Could you please better explain the concept on the stress induced by partial throttle closure?
In particular, at the same engine rpm and pressure in front of throttle valve, which turbo wheel is rotating faster? A) the one with 100% valve opening B) the one with 50% valve opening |
01-27-2010, 06:01 PM | #3 |
104
Rep 2,368
I think u can imagine it this way, if theres throttle closure, essentially the turbos will be spinning into a closed system/space. Its like blowing into a closed cup with a straw trying to maintain pressure. Youll feel the strain in ur cheeks. If theres a hole now in that cup, throttle wide open, then your stressed less even tho you push through more air. Turbos will spin but not be strained from backpressure?
01-27-2010, 06:01 PM | #4 | |
Moderator
270
Rep 4,481
Please PM your email address where I can send a BT log (excel) with AT shifts on WOT. From my flashed car. Eugen |
01-27-2010, 06:08 PM | #5 |
296
Rep 1,515
Drives: Ever changing fleet
A turbo spinning at 100k rpm may generate 10 psi at WOT. 13-14 psi against the pressure side of the blade at the exact same compressor rpm against a throttle plate 50% open. There's a bit more force on the CHRA and shaft just from the higher pressure against the wheel, but nothing that would wear thrust collars or the bearings. Thrust collars are worn out by axial loading, typically from being spun to high enough rpm that the effective balancing becomes a bit suspect which allows fore/aft movement of the rotational assembly from the vibration induced...most occurs when the turbo is hung out, a full 360 deg collar isn't used, and frankly, the turbo isn't especially well put together and has a bit of excessive play. The fore/aft movement is also, obviously, an issue for the dynamic bearing and it's seals as well.
Edit: I almost completely reworded my post as I obviously did not manage it put into coherent english what I was trying to get across...it's been a long day at work
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
01-27-2010, 06:16 PM | #6 | |
39
Rep 672
Where do you get your knowledge on turbo vehicles? Have you worked on them before? Do you know about injection systems. Statements such as this show a lack of knowledge, and in a public forum show a desire to derail a product by creating doubt and confusion. There is absolutely no extra stress on the fuel system. It operates at pressures MANY times great than boost pressure (like 100s times) and much greater than combustion pressure. The small change in boost would not even be in any way noticable to the fuel system. The Procede controls fuel pressure independantly of boost. It is more stressful on the pump to run continuous high boost which will be on average lower with V4. As for the turbo, in terms of acceleration and decleration of the turbine, the most deceleration of the turbine is in the situation that Shiv mentioned... closing the throttle. This is why BMW put the BOVs in there... to reduce this deceleration which can effect turbo service life. In terms of acceleration of the turbo... well most turbo engines ran wastegates that are fully closed until the actuator pressure. So until you reach that the turbo acceleration is only limitted by the inertia of it and the air. In V4, we have that limit also. It is generally recognised that you cannot over accelerate a turbo. Manufacturers strive for minimum lag which mean they accelerate it as much as possible. The worst case acceleration is going from (at high RPM) min boost to max boost. By nature, the adjustable boost point with throttle on V4 will actually reduce occurances of this, as the driver will more often go for lower boosts since they now have more control. So instead of going low speed to max speed, you are more likely to go from low/medium speed to high/medium speed in most driving. Adrian |
01-27-2010, 06:21 PM | #7 | |
Rep 200
The throttle blade in the n54 is used as part of TORQUE control so that if the actual pressure BEFORE the throttle itself exceeds (by a minimal amount) the target, a (relatively slow) closure is induced keeping the same boost level with simultaneous reduction of wastegates dc. So I ask again: with the SAME boost level, which turbo wheel is more stressed? A) 100% throttle opening B) 50% trottle opening |
01-27-2010, 06:25 PM | #8 | |
1737
Rep 17,960
Drives: A Lot
But if you are assuming we hold the TMAP pressure equal, then the other turbo will likely be spinning slower because it's pushing against an engine with reduced pumping efficiency. But the engine (and the driver) doesn't care about TMAP pressure. That's just a measurement of the air that doesn't get into the engine. We only really care about the manifold pressure (downstream of the throttle body.) Shiv Last edited by OpenFlash; 01-27-2010 at 06:30 PM.. |
01-27-2010, 06:36 PM | #9 | |
Rep 200
But this is not the case we are considering here. The controlled value is the boost level (I repeat) BEFORE throttle valve and a closure of the latter happens for the sole purpose of torque REDUCTION. So... |
01-27-2010, 06:49 PM | #10 | |
1737
Rep 17,960
Drives: A Lot
Shiv |
01-27-2010, 07:14 PM | #11 |
Rep 200
My point is quite simple:
all the tunes I analysed (giac,jb3,Aa,stock tune, power kit, provede v3) cause some degrees of throttle closure but keeping constant pressure in front of throttle valve (the only measured one... also for v4). So, if you set a target of 14psi for such 'flawed' systems and the same level for v4, the result will be the following: better performance on v4 because of less closure but more stress on the turbo wheels. In other words... A jb3 at 14psi is (probably) slower than V4 at 14psi, but do not involve more risks for the engine... beside lack of timing control . Last edited by Prince ///M; 01-27-2010 at 07:21 PM.. |
01-27-2010, 08:05 PM | #12 |
153
Rep 5,780
01-27-2010, 09:24 PM | #13 | |
296
Rep 1,515
Bah, I don't like the corvette forums...its a bunch of old guys showing off their latest ricer mods (air brushed corvette flags on anything you can possibly imagine, along with making anything your heart desires chrome under the hood) Frankly turbo systems are more complex and much more interesting from a technical standpoint. There's really only so much arguing you can do over LSA, duration, and lift before its boring. As for the car, I freaking love it. Simple, to the point, and ohmigod the power of this thing. I only trapped 123.x when I ran it, but on the street if you aren't every bit of a 130 mph vehicle, you'd better watch out
01-28-2010, 10:22 AM | #14 | |
76
Rep 1,883
**************************car-videos-09...35&PID=3147428
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
01-28-2010, 10:58 AM | #15 | |
654
Rep 10,587
that is too funny lol reminds me of the guy driving an e60 M5 at one of our MIR rentals that thought he was doing a burnout, turns out he was frying his DCT tranny
01-28-2010, 08:45 PM | #16 | |
34
Rep 367
2019 Ram 1500. (Toy hauler)
2009 M3 Vert (Fun in the sun) 2006 330i 6sp manual. (Commuter) 1999 528iT 5sp manual (new addition) |
01-28-2010, 11:31 PM | #18 | |
102
Rep 2,760
E92 335 | Space Gray | Saddle Brown Dakota | Dark Burl Trim | ZPP | ZSP | AT | Idrive | 6FL | FBO | Dinan CAI | Quaife LSD | STG3 PROCede.
