Driver's Air Bag Removal
Anyone have a DIY link to this? I am going to mod my shifters from push/pull to pull/pull. I found the DIY for that and part of it is remove driver's airbag. I found a thread on doing that but it seems a little too simple for me to believe. And the slots that they show for it are not there on my car. So I am assuming that something has changed since it was written. Simply says to disconnect battery and slide a flat screwdriver in the slot and the airbag will pop right off. First I have no FLAT slots where they indicated and second I do have some holes in the back of the steering wheel. They are round and I have also read something about using a torx driver on the newer cars. But they these holes do not SEEM to be in the right place to facilitate removing the air bag. Has anyone done this to replace a steering wheel or something and can you point me to a good DIY or give me instructions. Any help would be greatly appreciated. I can not use the push/pull shifters on my car because the push part can not be reached by my short little fingers So I can only upshift... simple solution is to go very fast I suppose Thanks.
