Mr 5 Intake - my version
01-26-2010, 05:28 PM | #1 |
42
Rep 822
Having followed the work that Mr 5 has done on his intake which utilises the stock air box, I felt that this setup has a lot of potential.
I have previously used a BMS single, but didn't really like the sound - I want stock sound, with a better flow of cool air. My solution uses 2" silicone hose, clamped together. Where the hose connects with the stock air box I have flattened out the end of an aluminium coupler and put an o ring behind it to achieve an air tight seal. The hose is obviously smooth on the inside, which gives good flow - even on the 90 degree corners. I have managed to route the hose that prevents it from being crushed by the wheel liner - achieving something that to my eye looks pretty stock. You will see below that I have cut the hole as low as possible on the side of the air box. I did this in an attempt to prevent turbulence between the air coming in from the top (via the panel filter) and the air coming in from the hose - I think this has worked pretty well, although it did cause some fitment issues to get the hose to clear some engine components. You will also be able to see that I have trimmed a couple of holes in the brake air duct so that it can pass some air through into the compartment close to the filter - it is not a ram air effect, but does allow cool air to be sucked into the filter from outside rather than it being drawn in from the engine bay. After a few attempts with different hoses to get the hose to route how I wanted it, I have achieved as below: To return my air box back to stock, almost - I have sourced a 2" cap and fitted an o ring behind it to seal the hole in my air box. Again, when fitted, this looks pretty stock - but obviously would stand out to a trained tech. It does work well though. This is the cap, not fitted though obviously: |
01-26-2010, 05:38 PM | #2 |
113
Rep 1,347
Drives: 2011 335d
Looks good. Any plans for dynos?
01-26-2010, 06:10 PM | #4 |
313
Rep 3,262
Looks very professional, congratulations !
01-26-2010, 06:28 PM | #5 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
That looks great. Good work.
01-26-2010, 08:40 PM | #8 |
654
Rep 10,587
ur the man
01-26-2010, 08:40 PM | #9 |
Modder Raider
753
Rep 8,633
Drives: M3
Great job man!!
I really need to do what you've done with the silicone hoses but I'm having a hard time trying to find something flexible with an ID of 2.75" I also need only 3 ft of it and people are selling only 12 ft lengths.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
01-26-2010, 08:45 PM | #10 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
subscribed
01-26-2010, 08:47 PM | #11 |
Mr. Nice Says Hello
636
Rep 16,662
you should get a group of people who are interested to split with you, i would be interested
01-26-2010, 10:56 PM | #12 |
56
Rep 1,311
It appears to be a very good location of the new intake stud
You may want to cut the protruding part of the hose clamps or use smaller clamps for a clean look. There are a few simple rules to make an installation looking professional. No more than two base colours in the engine bay, cover new cables with black shrink tube or similar, screws (and hose clamps etc.) should be of the right length, cables should be hidden or be straight or have smooth bends and be fixed if visible. Sorry for preaching, I’m just visualising how to finalize similar ongoing mods in my car. |
01-26-2010, 11:20 PM | #13 |
www.facebook.com/Synergy69
24
Rep 505
subscribed!
01-27-2010, 07:55 AM | #15 |
153
Rep 5,780
01-27-2010, 08:07 AM | #16 |
42
Rep 822
I didn't end up using the flexible hose that I bought. I achieved this with 1 x 45 degree elbow, 2 x 90 degree elbow and a 3" to 2" reducer - this provides the perfect fitment imo.
01-27-2010, 04:08 PM | #18 | |
58
Rep 1,906
Drives: black 335i e90 PRE-LCI
they've have all kinds of vacuum hoses and air ducts from varying sizes and types of material... just have to search their site
01-27-2010, 04:49 PM | #19 | |
Modder Raider
753
Rep 8,633
Drives: M3
Thanks a bunch!!
01-27-2010, 05:24 PM | #21 | |
313
Rep 3,262
01-27-2010, 05:26 PM | #22 |
313
Rep 3,262
I wonder if 2.5" tubing would work instead of the 2" used ? I like the routing from behind the power steering reservoir, it spares me from relocating some fan relay. I think a 2.5" would be a bit strangled in that area...or not ?
